Old 12-14-2015, 12:39 PM   #21
Wa11y757's Avatar
Yes...Mine was in Indiana...
Wa11y757 is offline   Reply With Quote
Old 12-14-2015, 01:16 PM   #22
caper's Avatar
Take the sewer vent cover off. We have a sewer vent over the bed area. When the cover was removed all I could see was the roof. The vent was installed for no apparent reason. My guess is they make the roof for all the different models and install vent were they might be needed for each model. The vent location on my trailer would be in the kitchen area of a front kitchen model. If the vent is not being used remove vent and put some tape over area.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-14-2015, 03:11 PM   #23
Shady camper's Avatar
Originally Posted by youroo View Post
Yours is a T built in the West Region and yours has the Optional Skylight! Youroo!!
Ah, makes sense now. Thank you youroo!
2016 Forest River Wildwood T27RKSS
2010 Ford F250 Lariat Crewcab PSD
Shady camper is offline   Reply With Quote
Old 12-15-2015, 12:00 PM   #24
Canadian Member
itat's Avatar
Is the vent just a simple vent or does it have a powered fan, too? Hopefully it has a fan so that you can turn it on a push air out rather than potentially having holding tank gasses come in. If you have the vent cover oriented correctly in your picture, adding the vent cover will eliminate the potential problem if you don't have a fan in the vent.
Even if you extend the vent pipe you won't likely be able to use one of the hinged vent covers.
If you contact FR about the design, let us know what they said.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 12-15-2015, 01:47 PM   #25
Wa11y757's Avatar
I contacted my dealer and service said he checked another unit on the lot and that he was able to put a max air vent, that he sells, over the vent. Meaning my camco my be too big.....they look the same to me. . I have not had a chance to go back up and compare pics. Maybe this weekend. Thx for all of you for the help too.
ID:	96257   Click image for larger version
Old 12-15-2015, 07:09 PM   #26
I used a max air 2 and just cut a small notch around the vent pipe.
2016 WILDWOOD 27RKSS
nook is offline   Reply With Quote
Old 12-15-2015, 07:33 PM   #27
TURBS's Avatar
