Old 12-13-2015, 03:40 PM   #1
Wa11y757's Avatar
Hmmm....what to do?
Picked up our 2016 27rkss yesterday. Tried to put vent cover on and.....no go! Any ideas?
Wa11y757 is offline   Reply With Quote
Old 12-13-2015, 03:46 PM   #2
wmtire's Avatar
That vent pipe is definitely in the way. Hmm. this may require some modification and thinking on.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 12-13-2015, 03:58 PM   #3
Flybob's Avatar
Poor engineering. Putting tank vent that close to fresh air vent. I can see odors coming in under certain conditions.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-13-2015, 04:02 PM   #4
RSchleder's Avatar
WOW, that is really poor engineering/design. I would be rather upset to have my fresh air vent and a tank/stool vent pipe within inches of each other. What were they thinking? Obviously---they WEREN'T!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 12-14-2015, 12:59 AM   #5
ramair's Avatar
Don't see anyway around this problem it would be a major job to move. Maybe contact FR and see what they say about this maybe they will do something for you?
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 12-14-2015, 05:02 AM   #6
Yes,remove the vent cap and install coupling on pipe now install Vent Cover and locate where you are going to Drill/Cut the hole for the Pipe that is going to slip into the coupling! Now remove vent cover and Drill/Cut hole,replace cover and install short piece of vent pipe to clear the outside of cover and place a New push on type vent Cap! The New vent Cover can still be removed just pull the vent Cap off and Lift straight Up! You can caulk around the Pipe where it exits the Cover if you like but the way the lid slopes water should not enter the trailer! PS if you use caulk do a Better job than the person who caulked the Roof Vent! Youroo!!
Old 12-14-2015, 05:09 AM   #7
Also you should look at MaxAir II covers or the Newer MaxAir covers they are Longer (Front to Back) and Might give you more to work with? The cover displayed seems to be a Short Cover? Youroo!!
Old 12-14-2015, 08:53 AM   #8
Shady camper's Avatar
I would contact FR. My trailer is not set up like that at all. I used a MaxxAir cover, but didn't have to contend with the vent.
Sent from Central Cali using Tapatalk
2016 Forest River Wildwood T27RKSS
2010 Ford F250 Lariat Crewcab PSD
Shady camper is offline   Reply With Quote
Old 12-14-2015, 09:39 AM   #9
ManlyMan's Avatar
I would leave well enough alone rather than giving yourself a bunch of grief right away.
If it turns out that you do get sewer odors because of the vent location then you can take action.
Life is short, go RVing.
ManlyMan is offline   Reply With Quote
Old 12-14-2015, 10:05 AM   #10
Wa11y757's Avatar
Not to worried about any possibility of sewer odor yet. I really just want to put a cover on my the only vent I have and that sewer vent is in the way. I can't put a longer cover on because I don't want the sewer cap under there too...hmmmm
