Old 11-27-2013, 09:10 PM   #21
kerrlakelover's Avatar
Originally Posted by OldCoot View Post
The bumpers are welded to the others, it isn't a matter of the weld, the bumpers are not strong enough to hold the weight, the bumpers themselves tear. I would predict someone will get a slightly scuffed up Champion 3100 genny.
That's exactly what happened to my 2005 Flagstaff (8528GTSS) bumper OC. The tube bumper twisted from the weight of the carrier and gen, the frame actually pushed into the bumper and the bumper ripped at the weld. I was also told by Forest River/Flagstaff that it would/could tweak the frame and cause the floor to loosen near the back of the FW. And believe it or not, after the damage to the bumper, the floor just inside the door had a squeak in it like it had loosened a bit and had some movement in it.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 12-09-2013, 10:32 AM   #22
BiigDaddy's Avatar
This is the basket on my Puma. It is a beast, but invaluable since I no longer have a pickup truck...
Name:	PUMA basket1.jpg
BiigDaddy is offline   Reply With Quote
Old 12-09-2013, 10:36 AM   #23
BiigDaddy's Avatar
The stock bumper was cut off and a new 1/4" square stock bumper was installed. It was reinforced to the frame, and it sits high enough that it clears anything I might encounter. It is removable as it is attached with two receivers. I have more pictures if anyone needs ideas.
Old 12-09-2013, 11:12 AM   #24
Is that a receiver out the back also? Youroo!!
Old 12-09-2013, 12:02 PM   #25
BiigDaddy's Avatar
It is, allegedly, another receiver. Lol.
