Old 05-11-2012, 12:46 PM   #1
Herk7769's Avatar
Homemade BlueBoy mount
Some folks have been PM'ing me about the mount I made.
Not really prepared to do my normal workup; but this will get them an idea of what I did.
To catch you up:
I was looking for a wall mounted portable tank carrier (no idea what make; but not mine) for my 42 gallon tote when I was in the RV parts department. The parts manager had a "product return" that had been missing parts. The manufacturer did not want it back apparently, so he sold it to me for 20 bucks cash.
I only used 3 metal parts (the powder coated black metal parts) from the kit as it turned out. I made the rest from 1 inch square "holed" stainless steel tubing and stainless steel 4 inch square "U" bolts from Grainger.
The photos were taken while I still had the generator on the "FAIL" rack.
I will try to get some better shots when I take the tank down.
ID:	13603   Click image for larger version
ID:	13604   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-11-2012, 12:55 PM   #2
Herk7769's Avatar
Details of how it is now.
ID:	13606   Click image for larger version
ID:	13607   Click image for larger version
ID:	13608   Click image for larger version
ID:	13609   Click image for larger version
Old 05-11-2012, 01:18 PM   #3
Alleged curmudgeon
Vern's Avatar
Thanks!
Thanks, Lou. That gives me something to think about.
Lee
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
Vern is offline   Reply With Quote
Old 05-11-2012, 03:16 PM   #4
Triguy's Avatar
Thanks Lou!
Could you confirm something? It appears in your setup that the bracket on the bumper holds the rack flush to the wall or did you have to secure the top of the rack with screws to the trailer wall?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-12-2012, 01:35 PM   #5
Herk7769's Avatar
Originally Posted by Triguy View Post
Thanks Lou!
No, The rubber crutch tips are compressed against the wall.
I made them from a bolt, fender washer inside the crutch tip through a hole through the steel upright and a lockwasher and nut on the otherside.
Old 05-12-2012, 03:46 PM   #6
Triguy's Avatar
That's what I thought but wasn't sure. Its a nifty setup.
Scott
2012 Shamrock 233S
Old 05-12-2012, 04:08 PM   #7
I simply use a ladder mounted chair carrier available for cheap and a large nylon strap. Been that way for about 6 years now with no problems. And no extra holes in the rear cap to worry about. Actually I was so cheap, I made my own chair carrier from a couple of pieces or 1/2 inch round bar, SIL welded it together for me and I sprayed it with some black rubber paint I found at Lowes.
