Old 08-15-2015, 08:55 PM   #1
CJM
Homemade hydraulic level system
Has an one done this. It is one of two options I didn't get on my 35qb4. The first was a fire place. That was easy. I have done some research and it appears to be a straight forward hydraulic system. Just need the controller, which would be easy to install. I'm sure I could put the system together cheaper than they sell for. Any info or opinions welcome.
CJM is offline   Reply With Quote
Old 08-15-2015, 10:25 PM   #2
2007 WildCat 32QBBS
18CrewDually's Avatar
I know you said hydraulic but here's what I did on my 07 Wildcat. It does have hydraulic front gear and slides. Simply for cost and ease of install, I went electric.
I purchased 2 electric tongue jacks through Walmart's website for only 99 bucks each. I ran a dedicated 10 gauge wire through a 30amp circuit breaker to the rear just aft the rear axle.
I used 2x4x.25" tubing for frame mounts that I welded to the jacks. I also cut down the jack tubes making them 7" shorter. I outfitted the jacks with the auto retracting 6" Flip feet @ 39 bucks ea. The assembly then is bolted through the frame with 1/2" bolts. The top of the mount rest tight against the top flange of the frame making it rigid.
Once wired up I am able to lift the entire coach off the ground if I want to. Each jack is independent and are still able to be manually retracted if there's failure. The jacks even have 2 LED lights that shine down on the foot for night time ops.
Here's some pics.
ID:	85837   Click image for larger version
ID:	85838   Click image for larger version
ID:	85839   Click image for larger version
18CrewDually is offline   Reply With Quote
Old 08-15-2015, 10:34 PM   #3
I like that.
Static54 is offline   Reply With Quote
Old 08-15-2015, 11:13 PM   #4
Kilday4's Avatar
Nice setup.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 08-15-2015, 11:24 PM   #5
Crockett's Avatar
Here's some pics.
that looks like the old ultra fab jack...it did not have a clutch as i remember. how does it respond at the end of its travel when totally retracted?
Crockett is offline   Reply With Quote
Old 08-15-2015, 11:40 PM   #6
2007 WildCat 32QBBS
They're made in China with no name on the boxes. No weak troublesome clutches. When retracted it folds the foot up and stops. The circuit breaker protects it.
Old 08-16-2015, 10:00 AM   #7
Crockett's Avatar
i used to just avoid running that jack against the stop. should be ok if you just feather it up to travel position. running up with full momentum may give you premature failure. the old ultra fab was rated 3500 pound and a durable jack. it looks just like it. nice mod IMO..
Old 08-16-2015, 02:04 PM   #8
This them 05CrewDually?
3500 lbs Electric Power Tongue Jack RV Boat Jet Ski A-Frame Trailer Camper 12V - Walmart.com
Didn't see any mention of the light but looks like them.
Old 08-16-2015, 05:02 PM   #9
2007 WildCat 32QBBS
Having trouble with my phone viewing the item. The little picture that I can see looks right. The price is right too.
Old 08-16-2015, 07:41 PM   #10
KarenDLS's Avatar
My DH wants to know how do you control the twisting of the frame since front jacks are not as controllable as the back ones.
1999 Ford F350 7.3 diesel.
2012 Sandpiper 346RET
Just absolutely love our 5er!
KarenDLS is offline   Reply With Quote
Old 08-16-2015, 07:49 PM   #11
more power to you, i would warn you not to twist the frame tooo mutch when leveling , like my level up system, when it works and it does now after being fixed at the FROG rally hats off to the tecks great job
Big Bill is offline   Reply With Quote
Old 08-16-2015, 08:30 PM   #12
2007 WildCat 32QBBS
After I unhook from my TV I lower the front gear so it is low in the front out of level. Then I go in the back and level side to side with the electric ones. Then I level it front to back up front with the hydraulic gear.
Keep in mind, the hydraulic gear in the front is self equalizing left to right so there is no twisting.
Old 08-16-2015, 08:36 PM   #13
2007 WildCat 32QBBS
I'm not relying on some computer that can get knocked out of wack and jack my coach to pieces. If you notice the jacks are near the axle. They are not adding any more stress than driving up a leveling Lego block.
I'm in full control and take full responsibility. It's really so simple and easily repaired or retracted with a simple 3/4" wrench. No worries of it getting stuck down or out of adjustment like some of those over - engineered systems.
Old 08-17-2015, 03:47 PM   #14
KarenDLS's Avatar
Here's some pics.
05CrewDually: Okay here I am again. DH would like to know how do you raise or lower the legs. Do you have to crawl under trailer or did you install switch or remote control? I guess what I need to ask is can you give more instructions on the install? Karen
Old 08-17-2015, 04:09 PM   #15
2007 WildCat 32QBBS
No crawling around. In the top pic is the toggle switch. Push it towards the center of the coach and the leg comes down. Pull it towards you and the leg goes up. The second pic shows my hand on the switch for operation.
It's a single hot wire hook up with it grounded through the chassis.
Old 08-17-2015, 05:33 PM   #16
CJM
Thanks. I think I will be going Electric. Just had hydraulic in my head, but that seems to work well. I'm going to use 4. Two at the rear and two by the wheels
Old 08-18-2015, 12:18 AM   #17
Crockett's Avatar
lookin better as we go...but im not a fan of one button stuff...
Old 08-18-2015, 06:37 AM   #18
2007 WildCat 32QBBS
What do you mean "one button stuff"? Each leveler has there own independent DPDT switch. Plus the main supply feed can be switched off. The only buttons are for the LED lights on the head.
Old 08-18-2015, 08:20 AM   #19
Crockett's Avatar
confusing post on my part...i like the concept but im not a fan of power awnings, level up, ect...
Old 08-18-2015, 08:31 AM   #20
2007 WildCat 32QBBS
I got ya now. You like the Armstrong stuff. I left enough clearance on the top of the housing to access the manual crank using a ratchet and 3/4 socket. Not only just incase of failure, but incase I forget how nice it is having them I can do it manually. I don't see me ever needing that reminder.
hydraulic
