Old 04-12-2016, 01:57 PM   #11
Originally Posted by kandl View Post
Ditto - a gross mismatch can even defeat the purpose of installing a second battery. For max effectiveness, purchase two new batteries of the same group and capacity.
Correct, weakest link in the chain cliché.
Same make and size no more than six months difference in age......
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 04-13-2016, 01:45 AM   #12
HI here is a century battery box that may work.
Century Plastics: White Heavy Duty Battery Box - (part#: GCE-G)
Hope this helps Tim
TimVWulp is online now   Reply With Quote
Old 04-13-2016, 12:47 PM   #13
nodrawers's Avatar
Hope this helps Tim
Thanks for this post. I have been looking for a way to mount two T105's for my new 400 watt solar. This will fit in my tongue battery slot just perfect.
Going to Grand Lake, OK tomorrow for 7 days.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 80
nodrawers is offline   Reply With Quote
Old 04-16-2016, 11:51 PM   #14
Tool box is called a "side mount truck tool box."
I just finished up all my wiring and trimetric installation.
Ive used about all the room available with my shunt and 1,2,both,off switch.
opie is offline   Reply With Quote
Old 09-19-2016, 10:14 PM   #15
265bhx's Avatar
I used a seperate battery switch slash disconnect to run two 6 volts and a seperate 12volt battery. Since both systems are seperated the battery's can be run one set at a time and they don't have to match just have a backup reserve when needed.
It was a tight fit but works and is secure.Click image for larger version
Name:	ImageUploadedByForest River Forums1474337666.225780.jpg
ID:	120741Click image for larger version
Name:	ImageUploadedByForest River Forums1474337683.566356.jpg
265bhx is offline   Reply With Quote
Old 09-20-2016, 08:12 PM   #16
I always tell people who want to add batteries that it is as easy a jump starting a car. Black to black, red to red.
We often camp in cold weather, sometimes in the dead of winter. Extra battery reserve to run a furnace is often a requirement.
Here's the way I've done it on three of our campers.
This is our '05 Bigfoot 10.6e. One big deep cycle marine battery with two Hawker SBS40 compact all fits nicely in the right rear compartment.
This is a typical front mount for a travel trailer. In this case it's a Heartland MPG. It came with one small marine battery, I simply connected a pair of Hawker SBS40. The batteries are placed in simple black boating battery boxes & secured to the carrier behind the propane tanks. I do suggest you drill 1/4" drain holes in the corners. I found towing in the snow or rain, that the moisture swirls it's way into the battery box. Note also, the connections are clean. I add a coating of NO-OX-ID to them to prevent corrosion.
We just bought a "used" 2016 Forrest River Nitro 5th wheel toy box. First thing I did was to install more battery capacity. It came with one battery in the right front compartment. The new connection is on the left side with red tape over the clamp.
I was able to route the new red lead through a frame tube at the top of the compartment. To prevent abrasion of the insulation on the wire I shoved a piece of gray plastic electrical conduit (top of pic) through the square tube to the left front compartment.
In the left compartment, I drilled a hole into the steel panel and used a self tap screw to make the black (ground) connection. Red coming in from the upper right is attached to again, a pair of Hawker SBS40 compact batteries.
I got those batteries from the job I retired from. We were required to change them out when their capacity no longer met company specifications. They still have many serviceable years but back up power for electronics required they be replaced usually each 3-4 years. The pair in the above picture are dated 2007.
Originally Posted by Wankrl7 View Post
I have been researching two batteries for my new trailer.
In numerous places I have read that using two batteries of different age and condition is a poor idea. They will constantly try to equalize their voltage causing wear. I am sure somebody will set me straight though.
While it is true to an extent and was mentioned in a follow up post - equalization can be an issue for grossly different capacity batteries -
So long as the batteries you are using are "healthy" they will work together and find their own balance.
In the above pics, the Hawker batteries will usually charge to 13.74vdc. The interstate battery, by itself was 13.44vdc. When combined, all three floated at 13.63vdc when full charged.
skruske is offline   Reply With Quote
battery
