Old 03-02-2014, 02:39 PM   #1
How to add a cable tv hookup?
Hi guys,
last year i purchased a 26 foot Salem RKS. It has tv connections inside the bedroom in the front, and in the middle above the dining table. Unfortunately these are the connections for the Air antenna and not cable. I looked around the trailer 10 times to see if there is an another hookup for cable but couldn't find it. When purchasing the trailer i never thought that it would not be there. Anyway, my questions are:
1. The Air antenna is in front of the trailer above the bedroom. Does that mean that the cable from it goes in the ceiling to both of the Tv hookups inside?
2. Can i just hookup park cable somewhere on the top of my rv, where the Air antenna connects to the rasing arm?
3. How to route the new Cable?
Kuba is offline   Reply With Quote
Old 03-02-2014, 05:03 PM   #2
mark0224's Avatar
Most I've seen have a place for a dish or cable on the side of the trailer. Look at the one that has the the power to it and open the plate see what you need go to radio shack they should be able to help you with the parts you need. Take a pic of inside the cover if you can't tell them what you need.
mark0224 is offline   Reply With Quote
Old 03-09-2014, 09:39 PM   #3
What year model is your 26 foot Salem RKS?
Terry & Teena Hocker
2013 GreyWolf 28bh
2012 Dodge 1500 5.7L Hemi
lonestar68 is offline   Reply With Quote
Old 03-15-2014, 09:19 AM   #4
Its 2012, i looked everywhere.
Sent from my Lenovo P780 using Forest River Forums mobile app
Old 03-16-2014, 10:26 PM   #5
Originally Posted by Kuba View Post
Hi guys,
Find the antenna booster power box. Remove it from the wall, the cable TV wire would connect there if one was installed. If no wire is there you can run one to it. If you are unsure how a local house electrical co can install it for you. You can find the manual for the winegard booter at this site http://www.winegard.com/kbase/upload/2452217.pdf
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
