Old 03-23-2015, 08:27 PM   #1
HappyCamper77's Avatar
How to attach coil hose to outside shower.
I want to remove my outside shower hose and replace it with a fitting for a typical garden hose. I have a easy coil hose with quick connect that I want to use for this. Any ideas how I can attach all of this and make it happen??
Ontario, Canada
2014 Dodge Ram 1500 5.7
2015 Rockwood Ultralite 2905ss
Ontario, Canada
2014 Dodge Ram 1500 5.7L
HappyCamper77 is offline   Reply With Quote
Old 03-24-2015, 08:12 AM   #2
extremebike's Avatar
Remove the outdoor shower head. The pipe for that is a 1/2 inch thread same as shower tube. I went to Home Hardware and asked for a 1/2 inch to garden hose adapter. (see pic below). The adapter also fits on the end of a RV water pumps so I have several.
Connect the shower pipe to the shower hose and then the adapter. You will then be able to connect your garden hose.
I also use the shower pipe and adapter combination to connect the shower hose to the turbo flush. That way I can rinse my black water tank at the Ontario provincial park dump stations. Since you are an Ontarian you know what I am talking about.
My conversion is in the trailer at the storage so I can't send you pictures of the little pipe I carry around. PM me if you need more info.
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is online now   Reply With Quote
Old 03-24-2015, 08:19 AM   #3
fonzie's Avatar
If you have this type of outside shower, take apart at faucet and bring hose to local hardware store and they will help you find what you need.
Name:	RV shower.jpg
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
show, shower
