Old 09-20-2014, 12:50 PM   #1
Perma-Newb
How to beat “The Fuzz”
While getting the trailer ready for a 2 week outing, I ran into this, the dreaded fuzz. The battery box was barely held in with these 2 screws.
ID:	63143   Click image for larger version
ID:	63144   Click image for larger version
2015 F350 Dually, 6.7 PSD
2014 V-Lite 30WIKSS, Diamond Package W/All the goodies
http://www.forestriverforums.com/attachments/signaturepics/sigpic50858_1.gif
EarlyRetirement is offline   Reply With Quote
Old 09-20-2014, 12:54 PM   #2
Perma-Newb
What I used to fix it...
Rustoleum Primer, and Bed Liner, 1/4” rubber matt, and some scrap Nomex honeycomb.
ID:	63146   Click image for larger version
ID:	63147   Click image for larger version
Old 09-20-2014, 12:56 PM   #3
Perma-Newb
Prep...
Wire brushed the fuzzy, corroded points, and ran the DA sander over the mounting plate with an 80 grit pad.
ID:	63149   Click image for larger version
Old 09-20-2014, 12:59 PM   #4
Perma-Newb
The box...
Needed more surface area to clamp on the box itself, so rather then just bolt heads I used 1/4” stainless fender washers on the top and bottom. I had to cut slots in the bottom of the box to accommodate the large washers.
ID:	63151   Click image for larger version
ID:	63152   Click image for larger version
Old 09-20-2014, 01:00 PM   #5
Our dealer didn't even bother using screws with our battery box. All they used was a friction strap and that wasn't even installed correctly. First thing I did was drill holes to mount it with bolts and nuts, painted all the holes/hardware and added a couple of drainage holes to keep it dry.
Nice job by the way.
keith_h is offline   Reply With Quote
Old 09-20-2014, 01:02 PM   #6
Perma-Newb
Finishing it up...
Pictures show the stainless hardware, the freshly coated mounting plate, and the finished box.
ID:	63154   Click image for larger version
ID:	63155   Click image for larger version
Old 09-20-2014, 01:05 PM   #7
Perma-Newb
My goal was to insulate the battery from the frame and make the whole thing more secure. Maybe this is why the fuse on my truck that controls the battery charging blew. Regardless, it’s a far cry from how the dealer installed the battery and much more road worthy. Hope some of my ideas help somebody down the road, enjoy.
Old 09-20-2014, 01:10 PM   #8
BiigDaddy's Avatar
Excellent How-to and accompanying photos! Turned out great, Thanks ER!
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
