Old 07-25-2015, 06:34 AM   #21
Cut a thin piece on a table saw from a 2x4 that will fit into the cut snugly. Glue it in and trim with a sharp chisel when dry. Wahlah, fixed and just as strong.
harderd is offline   Reply With Quote
Old 07-25-2015, 06:09 PM   #22
I just used some shims that i used for my home renovation project that were thin enough on the tip to jam into the cut seam with some epoxy and then put more epoxy on the outer visible seam to make sure that it wasn't going to go anywhere. All is good now
Thanks for the tip!
stevespopup is offline   Reply With Quote
Old 07-26-2015, 06:58 AM   #23
Why can't you drill a 1/4" hole +/- next to screw and then use a wire coat hanger to feel what is in hoof front back left right direction
Jim in Halifax is offline   Reply With Quote
Old 09-12-2015, 02:57 AM   #24
Okay everyone, my install went well and I've finally been able to make a video of the install and post it on youtube. It's a very long video but extremely comprehensive.
280, rockwood
