10-12-2010, 07:25 PM
How to prop the door w/ the awning out?
I wanted to see if there is a more official/better solution to keeping the door prop'd open when camping. I came up with an improvised solution using a bungee cord! I put a glove btwn the awning post and door so it wouldn't rub...
Is there a better solution?
2006 Nissan Frontier Crew
2011 Surveyor SP275
10-12-2010, 08:58 PM
Without a picture of the whole camper it's hard to say, but that is the first one I have seen configured the way yours is. It looks as if your awning was 2 foot longer, then the door and door holder would all be under the awning. I've never seen an awning stop between the door edge and the door holder, but then I haven't seen everything. I guess one other solution would be to unclip that post and put it in "carport" mode, then, you could use the door holder.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
10-12-2010, 09:11 PM
Our door is also very close to the awning arm. Rockwood installs a door closer (cylinder) that holds the door open.
Dave
10-13-2010, 05:30 AM
Dave
I have had problems with the cylinder. The bracket on the door is held in with sheet metal screws. Opening and closing the door works them loose and elongates the holes. TT side is fine. I have temporarily removed the cylinder until a permanent fix can be made. When we bought the TT is June, I liked the cylinder idea but also thought that it would work loose. May work on a resolution this weekend. I'll pass it along for anyone else that has the same problem.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
10-13-2010, 07:07 AM
That is a common situation. I take it that you don't want to release the awning arm and move it to the straight up and down position? When I didn't feel like doing that, I did what you have done and used a bungee cord.
10-13-2010, 07:17 AM
Jan Goldfield
Question: Next to the little post that holds your door open, there is a tiny tube. What is it? What's in there?
Jan Goldfield and Donna Morse
Slidell LA
2009 Cherokee Grey Wolf 28BH
2009 Ford 150
10-13-2010, 07:45 AM
It's a door stop. It acts as a bumper.
10-13-2010, 07:49 AM
Jan Goldfield
Thanks much, Mike. I keep looking for where coax would attach to the Grey Wolf. I couldn't imagine sticking it in that little tube, but I was willing to try.
Sorry for the thread hijack.
Slidell LA
2009 Ford 150
10-13-2010, 09:51 PM
On my bedroom door of my Rockwood I have this same set up but the little catch arm is bent at a 90 degree and closer to the door so it hold the door open at a 90 degree position.
http://rvadenver.com/latches_and_fasteners.htm
08 Toyota Tundra 5.7
09 Rockwood Windjammer 3001W
10-15-2010, 06:58 PM
tks for the replies! I just wanted to make sure I wasn't missing the obvious!
Great link DCRC!!!
2011 Surveyor SP275
12-12-2010, 09:48 AM
how about a magnet cabinet door latch mounted to the door and glue the strike pad to the awning in the area the two meet
might work, might not, it is a weird set up
12-12-2010, 02:05 PM
Villa Estate 392FLFB
hmm that might work if the door is metallic. i know mine isnt. tried to put magnets up to hold a blind.
One state/province at a time!
12-12-2010, 04:12 PM
you would have to attach the magnet and stike plate ( some kind of stong glue or small sheet metal screws )
12-15-2010, 06:30 AM
Only problem I see with magnets is rust, and the stains rust make.
Kirk, KN1B
12-15-2010, 03:31 PM
you maybe right on the rust, i will look at home depot the next time i am there, it seems to me that there maybe some kind of plastic or rubber type cabinet door holder, i think it is like a small shaft with a ball on the end that would stick inside a rubber thing, sorry i dont have the right names for it
check this out http://www.sailorsams.com/mall/door_holder.asp
12-23-2010, 01:59 PM
You need an Angled Door Holder. You would need to mount it clode to the door edge, but it should work.
Check this link:
RV door catches, latches, holder, fasteners, accessories
Chuck Roder & Family '07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab High Springs, FL.
