Old 10-12-2010, 07:25 PM   #1
stepside's Avatar
How to prop the door w/ the awning out?
I wanted to see if there is a more official/better solution to keeping the door prop'd open when camping. I came up with an improvised solution using a bungee cord! I put a glove btwn the awning post and door so it wouldn't rub...
Is there a better solution?
2006 Nissan Frontier Crew
2011 Surveyor SP275
stepside is offline   Reply With Quote
Old 10-12-2010, 08:58 PM   #2
Without a picture of the whole camper it's hard to say, but that is the first one I have seen configured the way yours is. It looks as if your awning was 2 foot longer, then the door and door holder would all be under the awning. I've never seen an awning stop between the door edge and the door holder, but then I haven't seen everything. I guess one other solution would be to unclip that post and put it in "carport" mode, then, you could use the door holder.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 10-12-2010, 09:11 PM   #3
Dave_Monica's Avatar
Our door is also very close to the awning arm. Rockwood installs a door closer (cylinder) that holds the door open.
Dave
Old 10-13-2010, 05:30 AM   #4
Dave
I have had problems with the cylinder. The bracket on the door is held in with sheet metal screws. Opening and closing the door works them loose and elongates the holes. TT side is fine. I have temporarily removed the cylinder until a permanent fix can be made. When we bought the TT is June, I liked the cylinder idea but also thought that it would work loose. May work on a resolution this weekend. I'll pass it along for anyone else that has the same problem.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 10-13-2010, 07:07 AM   #5
That is a common situation. I take it that you don't want to release the awning arm and move it to the straight up and down position? When I didn't feel like doing that, I did what you have done and used a bungee cord.
Dan Kennedy
Prince Edward Island, Canada
2011 36RE Cedar Creek
2011 6.7 Ford 1 Ton Dually
http://snowyowl.smugmug.com/
Snowyowl is offline   Reply With Quote
Old 10-13-2010, 07:17 AM   #6
Jan Goldfield
pondlady's Avatar
Question: Next to the little post that holds your door open, there is a tiny tube. What is it? What's in there?
Jan Goldfield and Donna Morse
Slidell LA
2009 Cherokee Grey Wolf 28BH
2009 Ford 150
pondlady is offline   Reply With Quote
Old 10-13-2010, 07:45 AM   #7
milzat's Avatar
It's a door stop. It acts as a bumper.
milzat is offline   Reply With Quote
Old 10-13-2010, 07:49 AM   #8
Jan Goldfield
pondlady's Avatar
Thanks much, Mike. I keep looking for where coax would attach to the Grey Wolf. I couldn't imagine sticking it in that little tube, but I was willing to try.
Sorry for the thread hijack.
Slidell LA
2009 Ford 150
Old 10-13-2010, 09:51 PM   #9
DCRC's Avatar
On my bedroom door of my Rockwood I have this same set up but the little catch arm is bent at a 90 degree and closer to the door so it hold the door open at a 90 degree position.
http://rvadenver.com/latches_and_fasteners.htm
08 Toyota Tundra 5.7
09 Rockwood Windjammer 3001W
DCRC is offline   Reply With Quote
Old 10-15-2010, 06:58 PM   #10
stepside's Avatar
tks for the replies! I just wanted to make sure I wasn't missing the obvious!
Great link DCRC!!!
2011 Surveyor SP275
awning
