Old 04-14-2018, 11:20 AM   #1
Mch5jdm's Avatar
How to secure TV when traveling
Hey fellow campers! Need some ideas on how I can secure/support a television that is wall mounted on a positionable mount that does not have a locking mechanism.
My concern is that though I hit a stud when mounting I am concerned that bouncing etc. will eventually loosen or break it free.
I donít like having to detach it every time as itís a pain.
I was thinking of using a strap or something but wanted to get a few other ideas.
Also, Iíd donít have a picture right now so weíll have to use our imagination.
Tv is 26Ē flat panel tv.
Letís go camping!
Mch5jdm is offline   Reply With Quote
Old 04-14-2018, 11:23 AM   #2
510Rick's Avatar
I dont like removing it either but thats what I do . Id hate to forget to strap it and have it flopping all over the place .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
510Rick is offline   Reply With Quote
Old 04-14-2018, 12:44 PM   #3
calgarycampers's Avatar
Go by a Primer Time dealer and have a look at the 330RST . It uses two straps and works well.
calgarycampers is offline   Reply With Quote
Old 04-14-2018, 05:14 PM   #4
Mch5jdm's Avatar
Thanks!
Letís go camping!
Old 04-14-2018, 05:48 PM   #5
Denver To Yuma In 90 Days
Or get one of these from Camping World:
https://www.campingworld.com/master-...er-mount-small
There is a larger one for bigger TV's.
I have two of them and have had them for five years in two different campers.
Love them and no straps needed!
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is offline   Reply With Quote
Old 04-14-2018, 06:15 PM   #6
Mch5jdm's Avatar
I like this mount but donít wanna abt to make more holes.
Letís go camping!
Old 04-15-2018, 01:48 PM   #7
CaptnJohn's Avatar
All 3 tvs in my 5er came with a strap that is mounted to wall. They have a snap buckle. Once snugged up only need to buckle after.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-15-2018, 02:09 PM   #8
DavidBo's Avatar
Not sure about your setup, but my TV is mounted in an alcove of sorts above the range hood. I cut about 16" from a hollow pool noodle then split it lengthwise along one side. When the TV is pushed all the way in, I stuff the noodle between the bottom of the set and the shelf below it, with the edge of the screen in the split side. There is very little clearance there so it's a tight fit, taking the load off the mount. So far the TV has stayed in place for several lengthy trips.
DavidBo is offline   Reply With Quote
Old 04-15-2018, 02:35 PM   #9
Mine has 2 straps that hold it to the wall above a shelf. I have over 10,000 miles on my rig with no problems. It's on my departure check list so I never forget it.
Max & Tina
2016 Prime Time
Spartan Toy Hauler
43 feet
CoMaddMax is offline   Reply With Quote
Old 04-15-2018, 02:35 PM   #10
Smile How to secure TV when traveling
We have a 39" flat panel. We use a flat bungee cord with eye bolts mounted above and below TV. Actually my son-n-law mounted the bolts and TV for us.
Bigben98 is offline   Reply With Quote
travel
