Old 11-03-2015, 11:58 AM   #11
Left Coast
Camco makes expanding (length wise) gismos to retain things in fridge....I use 'em in pantry to keep stuff from opening door
Old 11-03-2015, 12:09 PM   #12
Why not screw your hooks directly into the bottom side of the shelf above each. Small cup hooks should be more than adequate. Loading would be more in shear also.
Not penetrating the walls is a much better move.
MtBiker is offline   Reply With Quote
Old 11-03-2015, 12:25 PM   #13
You could use adhesive if you cant find the studs. I would use construction grade liquid nails. It will not let go of anything. I have seen 2x6s glued together with this and then have them hold 300lb equipment on sites. It would pull your paneling off before giving way.
j free is offline   Reply With Quote
Old 11-03-2015, 12:48 PM   #14
Thats exactly what I did with the Command hooks and what I'll do with this setup but where would the hooks go to hold back the stuff on the uppermost shelf?
Cedar Creek 38FB Ram 3500 Dually
bobsue1 is offline   Reply With Quote
Old 12-06-2015, 08:26 AM   #15
If you NEVER want to remove the boards again use any pro quality construction adhesive
I use PL 9000 never fails
gronotte is offline   Reply With Quote
Old 12-10-2015, 03:16 AM   #16
Name:	ImageUploadedByForest River Forums1449738812.488806.jpg
ID:	95880i used construction glue when I mounted the coat rack in the garage of our XLR and has worked great. I just put some one the back and then put a few short pin/nails in them to hold until the adhesive dried and then screwed the coat rack on with screws long enough to go through the maple board and in to the wall.
the.wilsons is offline   Reply With Quote
Old 12-10-2015, 11:24 AM   #17
ccsvolsfan's Avatar
The problem with const. adhesive is you are applying it to a wall covering applied to thin plywood. The wall covering can and will peel off. Look for an expanding anchor at hardware dept.
ccsvolsfan is offline   Reply With Quote
Old 12-11-2015, 08:10 AM   #18
I have used these pop toggles both at home and in my travel trailer. I like that it doesn't depend upon crushing the inside against the wall in order to be ready for the screw.
I use them mostly to hang wall track for shelving. In the TT I put one in every mounting hole.
http://wedo.hillmangroup.com/viewite...-toggle-trade-
2014 Coachmen Catalina 273DBS
50th Anniversary model
acope is offline   Reply With Quote
