Old 07-22-2015, 09:49 PM   #11
Ok parts on order to convert the non-ducked a/c unit to a ducked unit. I will post some picks during the process.
willy13fl is offline   Reply With Quote
Old 07-26-2015, 11:36 AM   #12
Thekipkers's Avatar
Can you provide a rough cost on the parts you ordered?
Why forest river didn't install this from the beginning is beyond me
Thekipkers is offline   Reply With Quote
Old 08-04-2015, 09:21 PM   #13
Upgrade completed.
Ordered parts from ppl moterhomes, cost $144 - ceiling assembly and thermostat kit
Parts from home depot, $50 - thermostat wire, low volt wire, HVAC tape
Still need to patch screw holes from old ceiling assembly. Took out rv for a long weekend at Disney World @ Orlando. Worked great.
Old ducting was all supplied by 15,000 btu unit in main room. I blocked off the ducting going to the bunk room, bathroom, and bedroom. This duct is now supplied by the 13,500 btu unit in the bedroom.
ID:	84954   Click image for larger version
ID:	84955   Click image for larger version
ID:	84956   Click image for larger version
ID:	84957   Click image for larger version
Old 08-04-2015, 09:28 PM   #14
Oh yea, just in case anyone was wondering, this upgrade took me alone about 14 hours. I took my time. I only had one issue when I was running the new thermostat wire. Took me a little longer to get new wire threw holes in wall at ceiling cap plate.
Old 08-04-2015, 09:42 PM   #15
Thekipkers's Avatar
thanks for the info, my dealer estimated close to 1k for this to be done.
Old 08-05-2015, 09:53 PM   #16
Garrette's Avatar
I can't get the a/c to come from the roof vents
I think that FR cuts the AC duct into the foam insulation assuming ceiling vents. If so, you probably have a blockage at the source stopping all air to the rest.
Garrette is offline   Reply With Quote
Old 08-06-2015, 09:54 AM   #17
R3Jones's Avatar
I found my unit was doing this as well. I took of the cover inside the unit and found the fins were frozen over which block air in to the unit. I turned off the cooling portion, turned the fan on high and it quickly melted the ice. Air flow returned and the ac returned to normal operation. Now I need to determine the cause of the freeze up.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 08-29-2015, 02:55 PM   #18
Your thermostat controller should have a freeze up probe pushed into the fins. It may have fallen out going down the road. Its just a wire with a small sensor on the end. Push it back between the fins CAREFULLY and CAREFULLY bend the fin back onto the probe to hold it in CAREFULLY.
Old 08-29-2015, 02:58 PM   #19
The probe sensor detects the freeze up and turns the compressor off to thaw it out. Same thing you did manually.
vent, air conditioner
