Old 05-22-2015, 02:24 PM   #1
I have a problem that needs a mod I believe.
Okay so here is my problem... I have a 2012 Cherokee grey wolf 28bh and I pull it with a 2004 ford expedition and I use the equalizer brand hitch. When hooked up I can't completely open my lift gate. Does anyone have any suggestions?
2004 Ford Expedition
2012 Cherokee Grey Wolf 28BH
2001 Rockwood Freedom 2280 popup <--For Sale
JTHale13 is offline   Reply With Quote
Old 05-22-2015, 02:33 PM   #2
Boss Ox & Drovergirl
oxcamper's Avatar
Someone on another post said you can turn the jack head around to the rear. I don't know if you really can, but it's worth a look see.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-22-2015, 02:42 PM   #3
fonzie's Avatar
Here's one thread....
http://www.forestriverforums.com/for...tch-58630.html
Fonzie
Old 05-22-2015, 05:11 PM   #4
deebarjay's Avatar
8" insert extension.
Tow Ready® 80307 - 2" to 2" Receiver Extender (3500 lbs TW, 8" Length)
deebarjay is offline   Reply With Quote
Old 05-23-2015, 12:20 PM   #5
You can turn the head around should be just the 3 bolts at the frame. Don't look like ull have the room due to propane so maybe just turn it to a side.
kinma13 is offline   Reply With Quote
Old 05-23-2015, 01:45 PM   #6
AKA: 'tiredTeacher
awellis3's Avatar
Yep, live with it.
You can't rotate the jack head 90° because the part where the gears and motor are isn't square. You can't rebolt the jack 120° using the existing holes because the propane tanks are in the way. You can't drill holes to rotate the whole assembly 90° unless you drill into the A-frame because the mounting plate is triangular (3 bolts). If you use a drawbar extender, that moves the load further from the rear axle creating more effort and leverage on the WDH.
Good luck.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-23-2015, 01:51 PM   #7
lil2low's Avatar
I pull a grey wolf 29dsbs with an expedition as well. Best solution I found was to just open the rear glass instead of the whole hatch.
lil2low is offline   Reply With Quote
Old 05-23-2015, 03:30 PM   #8
Take the electric one off and put on a manual
Crank one !
cj06 is offline   Reply With Quote
Old 05-23-2015, 03:44 PM   #9
asquared's Avatar
Try turning the jack sideways. We installed one on our old tt when we had an armada. It worked well sideways. To change it out simply hook up and then remove and reinstall the jack.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-23-2015, 03:48 PM   #10
Take the jack off and take it to a welding shop and have it rotated 90°.
Old 05-23-2015, 04:06 PM   #11
FordHauler's Avatar
Here in Kentucky we would just take a sawzall to the hatch! Easy mod.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 05-23-2015, 08:41 PM   #12
The only thing I would worry about if you just turn it 1 bolt at the frame is if it don't have a swivel wheel and it has a foot the stability might be off. U could redial the foot hole to fix that though.
Old 05-23-2015, 08:48 PM   #13
Originally Posted by awellis3 View Post
...You can't drill holes to rotate the whole assembly 90° unless you drill into the A-frame because the mounting plate is triangular (3 bolts)...
Have a welding shop cut the triangular plate off and re-weld it so the jack is rotated 90°.
Old 05-23-2015, 08:55 PM   #14
Turn ours to the side! Just like all the others I have done! Youroo!!
Old 05-24-2015, 06:53 AM   #15
SCHYBOLT
Load before you hitch. Unhitch before you unload. I have the exact same problem.
SCHYBOLT
2011 FORD EXPEDITION
5.4L 6-SPD AUTO
2014 CATALINA 263RLS
VANS RV7A
schybolt is offline   Reply With Quote
Old 05-24-2015, 07:13 AM   #16
Camping World has a unit called Jack-E-Up that allows you to remove the jack. Google their Web site. Showed a kit for the round base plate on a electric jack.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 05-24-2015, 11:12 AM   #17
AKA: 'tiredTeacher
awellis3's Avatar
OC, I think you have the answer. I owe you a cold one.
Wright
Wright and Penny
Richmond, Va.
Old 05-25-2015, 02:32 PM   #18
InTheSticks's Avatar
The same issue with my truck tailgate. Only solution I had was move the jack back, used a piece of 1/4" thick 5" wide C channel, welded it in... can open tailgate with no issues now. Looked at all the other options and none would give me enough to drop the tailgate.
InTheSticks
2022 F150 Lariat, FX4 - Appearance Package
2013 Forest River XLR 27HFS
InTheSticks is offline   Reply With Quote
Old 05-25-2015, 03:11 PM   #19
BamaBob's Avatar
Wright
In general, when OC speaks, folks should listen. You made a wise decision Wright!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-25-2015, 09:35 PM   #20
Lil2low - have you ever had a flat on your expedition while towing your tt? I have and that's part of my reason for wanting a hatch that will fully open without unhooking.
modifications
