Old 05-22-2015, 02:24 PM   #1
I have a problem that needs a mod I believe.
Okay so here is my problem... I have a 2012 Cherokee grey wolf 28bh and I pull it with a 2004 ford expedition and I use the equalizer brand hitch. When hooked up I can't completely open my lift gate. Does anyone have any suggestions?
2004 Ford Expedition
2012 Cherokee Grey Wolf 28BH
2001 Rockwood Freedom 2280 popup <--For Sale
JTHale13 is offline   Reply With Quote
Old 05-22-2015, 02:33 PM   #2
Boss Ox & Drovergirl
oxcamper's Avatar
Someone on another post said you can turn the jack head around to the rear. I don't know if you really can, but it's worth a look see.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-22-2015, 02:42 PM   #3
fonzie's Avatar
Here's one thread....
Power tongue jack and Suv hatch
Fonzie
Old 05-22-2015, 05:11 PM   #4
deebarjay's Avatar
8" insert extension.
Tow Ready® 80307 - 2" to 2" Receiver Extender (3500 lbs TW, 8" Length)
deebarjay is offline   Reply With Quote
Old 05-23-2015, 12:20 PM   #5
You can turn the head around should be just the 3 bolts at the frame. Don't look like ull have the room due to propane so maybe just turn it to a side.
kinma13 is offline   Reply With Quote
Old 05-23-2015, 01:45 PM   #6
AKA: 'tiredTeacher
awellis3's Avatar
Yep, live with it.
You can't rotate the jack head 90° because the part where the gears and motor are isn't square. You can't rebolt the jack 120° using the existing holes because the propane tanks are in the way. You can't drill holes to rotate the whole assembly 90° unless you drill into the A-frame because the mounting plate is triangular (3 bolts). If you use a drawbar extender, that moves the load further from the rear axle creating more effort and leverage on the WDH.
Good luck.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-23-2015, 01:51 PM   #7
lil2low's Avatar
I pull a grey wolf 29dsbs with an expedition as well. Best solution I found was to just open the rear glass instead of the whole hatch.
lil2low is offline   Reply With Quote
Old 05-23-2015, 03:30 PM   #8
Take the electric one off and put on a manual
Crank one !
cj06 is offline   Reply With Quote
Old 05-23-2015, 03:44 PM   #9
asquared's Avatar
Try turning the jack sideways. We installed one on our old tt when we had an armada. It worked well sideways. To change it out simply hook up and then remove and reinstall the jack.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-23-2015, 03:48 PM   #10
Take the jack off and take it to a welding shop and have it rotated 90°.
modifications
