Old 07-02-2017, 05:32 PM   #1
I have Awning Poles!
Thanks to an awesome forum member I now have awning hold down poles. A pair of brackets showed up the other day and I installed them today. I bought poles at Home Depot. They aren't the greatest but they'll do for now. Easy project for anyone thinking about doing it. I need to trim them a bit so I can open the basement hatch while the awning is in, I just didn't have anything with me to cut it.
So now I'm wondering if I NEED deflappers. Is the purpose of those to help keep the awning from getting torn off the camper?
2015 Ram 3500 CC SRW SB 6.7 Diesel Powered Baby! 2015 Sabre 36QBOK-7
2015 Nights Camped: 23
2016 Nights Camped: 27
2017 Nights Camped: 29
2018 Nights Camped: 12
mikeysotp is offline   Reply With Quote
Old 07-02-2017, 05:49 PM   #2
Well..........IMO...the best way to keep an awning from being ripped off your trailer...if it's getting windy, or possible storm coming...just put the awning away. Neighbor earned his awning pilot's license last year when sudden storm came up and before he got it unlocked to put away...he was laying 60' across the road...still holding the rail from awning. I don't trust tie down ropes either. I had to rebuild an awning once...(not due to wind)...and I've gotten a little gun shy to anything that might cause damage.
TheWolfPaq82 is offline   Reply With Quote
Old 07-03-2017, 01:04 PM   #3
I know that no matter what you do, the awning needs to come in during storms and heavy winds. I just want to be able to leave it out on breezy days and be able to leave the CG for a bit and not worry about the thing getting shredded.
Old 07-03-2017, 01:08 PM   #4
Mr. Dan's Avatar
Sounds like you're good to go. I use them with great success... with poles I made using PVC conduit from H.D.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 84; booked = 13
Old 07-03-2017, 02:24 PM   #5
Just realized I forgot to post the picture:
Old 07-03-2017, 02:29 PM   #6
SeaDog's Avatar
They look good and are one of the best mods you can do. I got mine from Trubs poles and old coot brackets and have not had a problem with my awning in wind or rain. I use ratchet straps and ground anchors to keep things tight. You will love them the more you use them.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-03-2017, 08:56 PM   #7
How does that work? I find the power awning is much less able to handle any wind than the old manual pull out types.
Kevinwak is offline   Reply With Quote
Old 07-03-2017, 09:10 PM   #8
Here are some examples. With the poles, ratchet straps and ground anchors, the power awning are just about as good as the old manual and a lot easier to deploy and retract.
Name:	GasPeddler Awning.jpg
ID:	143538   Click image for larger version
Name:	Awning tie downs completely set up.jpg
ID:	143539   Click image for larger version
Name:	Awning being retracted with poles.JPG
ID:	143540   Click image for larger version
Name:	Awning Tie Down Poles.JPG
ID:	143541   Click image for larger version
Name:	Awning Tie Downs worked great.JPG
Old 07-04-2017, 07:25 AM   #9
david_reaves's Avatar
I definitely need this! I've hated the automatic awning on my Windjammer simply because it can't be left out even it a light breeze. Like you, Kevinwak, I preferred the manual awning on my previous camper. It didn't matter that it took 3 or 4 minutes to put up or take down. Since I could lock it in place I didn't have to put it in and out 6 times a day...
david_reaves is offline   Reply With Quote
Old 07-04-2017, 10:26 AM   #10
Doesn't the wind still get under the awning and billow it's? With the locking knobs, why does it make such a racket in the wind, without the poles?
AbdRahim is offline   Reply With Quote
awning
