Old 02-07-2014, 02:10 PM   #11
Name:	ImageUploadedByForest River Forums1391803768.810121.jpg
The Sat receiver is mounted in the bottom shelf of the entertainment area, and I used the upper cabinet for cable routing, though it does not look it there is still room to store items in this cabinet.
Terry & Teena Hocker
2013 GreyWolf 28bh
2012 Dodge 1500 5.7L Hemi
lonestar68 is offline   Reply With Quote
Old 02-07-2014, 02:11 PM   #12
Name:	ImageUploadedByForest River Forums1391803855.366616.jpg
I have designed the setup as so that I will be able to watch any of the video combination on the four different TV locations in the trailer. I can watch DVD in the bedroom and living room, I can watch Sat at all four locations as well as Antenna at all four locations.
2013 GreyWolf 28bh
Old 02-07-2014, 02:12 PM   #13
Name:	ImageUploadedByForest River Forums1391803924.281508.jpg
2013 GreyWolf 28bh
Old 02-07-2014, 02:21 PM   #14
Originally Posted by JTHale13 View Post
Okay I have a 2013 Cherokee Grey wolf 28bh but to my knowledge I don't have a satellite cable pre ran in my camper. In your pics what is the black device on the wall with the green light and cable lines hooked to it? Also is there anyway you could post some pics taken a little bit further away so I can tell where these items are mounted in the camper? If I understand correctly we should have the same camper but I'm kinda thinking they aren't the same.
Sent from my SGH-M919 using Forest River Forums mobile app
No problem on the pics, That black box mounted on the wall is the power supply for the LNB to the sat. Keep in mind I swapped out the factor antenna/powersupply plate for the Winegard plate that has a seperate antenna/Sat hookup. On the drivers side front do you not have a cable/sat hookup on the outside?
2013 GreyWolf 28bh
Old 02-07-2014, 11:31 PM   #15
Lol I just realized I was having a "blonde moment" I have a 2012 rather than a 2013. Which probably explains the difference.
2004 Ford Expedition
2012 Cherokee Grey Wolf 28BH
2001 Rockwood Freedom 2280 popup <--For Sale
JTHale13 is offline   Reply With Quote
Old 02-07-2014, 11:34 PM   #16
How do you upload pics to this site? I took some pics of mine to show the difference. I was also wondering where your fourth TV location is. I have one in the living room area, one in the master bedroom, and one outside.
Old 02-07-2014, 11:47 PM   #17
I mounted the one that came with the trailer In the upper bunk near the outlet. If you are using the mobile. There is a picture icon in the text input area.
2013 GreyWolf 28bh
Old 02-07-2014, 11:49 PM   #18
I took the wall mount from the living room area. I installed a moveable type mount in that location so I had the spare mount.
2013 GreyWolf 28bh
Old 02-08-2014, 12:49 AM   #19
This is all I have on the outside as far as a TV input. It's near the left front of the camper.
Old 02-08-2014, 09:08 AM   #20
I have the same type of input but it is labeled Cable/Sat it is a single cable going to the inside connection. This is what yours should look like on the inside. and in order to use the cable function you have to have the booster turned off. I wanted to be able to use Sat and Antenna on different TV's at the same time so I switched plates. I could have just modified this plate but I think the other just looks cleaner.
2013 GreyWolf 28bh
