Old 06-13-2013, 10:51 AM   #11
We tried leaving space and it worked! Traveled some rough road also. Chairs never moved. Must be very good suspension systems in these trailers!
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 06-13-2013, 11:34 AM   #12
I cut a foam swim tube or water pipe insulation tube to about 5" long, cut a slit down the side and slip one over the edge of the top of the chair. They stay in place and remove easy to store when you park. If you use the water pipe tube they have a glue strip to hold them closed on a pipe. When you slit the tube cut trim the slot to remove the glue side when you slit it.
Bob & Rose, Greenfield, IN
2014 Flagstaff Micro Lite 23FB
Ford F150 ECO Boost 3.5L V6
3.73 Electronic Lock
Max Trailer Tow Package, 600# Equlizer 4
w9ila is offline   Reply With Quote
