Old 05-10-2016, 07:43 AM   #11
I have considered placing a switch in the power line for the radio so that I can eliminate the parasitic draw while dry camping. As I noted in my thread on the electrical system, Roo 19 Electrical the radio draws 42 mA when off. Now that I added the 3rd battery, I'm not sure it is worth it though.
I noticed that there is an amplified connection for a sub woofer on the system. I doubt it has much power but a small, even cheap, 8" sub would likely make a big difference. I likely won't bother since our primary use is local news and weather reports while camping. Space is also at quite a premium, but a larger trailer would decrease the space issue. Connecting a sub would increase the amplifier load so you may want to insert a switch for the speaker if you do a lot of boondocking and use the radio a lot.
I often use the radio with the outside speakers while out working in the lawn. Just wish it was easier to turn the camper around to point the other direction for when I am in the garden
Early 2016 Rockwood Roo 19
dragon-roo is offline   Reply With Quote
Old 06-15-2016, 11:57 AM   #12
My husband thanks you for the quick tip to cut the harness and create a true left/right channel in the interior speakers. As you said, it is as if the radio finally came to life. Songs that had different instruments and/or audio between the left/right channel were just missing parts of the music or song. It sounds so much better after moving the zone two speaker to the other zone one connection.
Feasba is offline   Reply With Quote
radio, reception
