Old 08-29-2014, 06:07 AM   #1
In search of the perfect stabilizer
I've read a lot of the "how do I stop my unit from moving/shaking" threads. Had an idea that I was looking for input on.
I'm thinking of buying two Reese cargo bars (the expandable/locking bars that are used to keep stuff from sliding around in your pickup truck bed). They are $19.99 at WM, and while towing, I would actually use these to keep things in place in the truck bed (i.e. plastic totes with kindling/firewood).
When setting up at the site, I'd no longer need them for securing items in the bed of the truck. It seems that they could fairly easily be converted to use as diagonal stabilizers (i.e. JT Strongarms) to help reduce movement. One diagonally between the two rear stabilizer jacks and one between the front two jacks. (Note - I have a home-made X-chock for helping with front-to-back movement.)
The appeal, to me, is that they would be dual purpose items, and that I have an automatic storage location for them while towing.
Thoughts? Anyone already doing this?
Thanks for any input.
Brian
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 08-29-2014, 06:15 AM   #2
TURBS's Avatar
I've been using cargo bars for a few years.
ID:	61685Click image for larger version
ID:	61686Click image for larger version
TURBS
"SABRE OWNERS UNITED"
Old 08-29-2014, 06:28 AM   #3
TURBS's Avatar
ID:	61688Click image for larger version
ID:	61689Click image for larger version
ID:	61690Click image for larger version
They work very well imo.
But I've made mine permanent.
Not sure how easy or time consuming it would be to make them "dual purpose"
TURBS
Old 08-29-2014, 07:09 AM   #4
Timex's Avatar
Originally Posted by f1100turbo View Post
Attachment 61688Attachment 61689Attachment 61690Attachment 61691
TURBS
Turbs, I'd get OC to "paint" those ends if I were you.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 08-29-2014, 07:15 AM   #5
TURBS's Avatar
Lol they've since been painted!
I didn't paint at first to make sure the prototype worked.
But he could come up and do some touch up with a q tip!
TURBS
Old 08-29-2014, 07:19 AM   #6
I'm sure when Ms. Amy comes to NC to live like a princess, we'll get everything fixed.
Old 08-29-2014, 07:26 AM   #7
Timex's Avatar
I guess if Turbs comes to NC, will he be a prince or a frog?
Old 08-29-2014, 07:30 AM   #8
Thanks Turbs. Re: making them dual purpose, the model I bought has nice rubber-padded swivel heads on both ends. If I just run them from top of one stabilizer to bottom of another, tighten until snug (letting the heads swivel as needed to accommodate the angle), am I good to go? Or, do you need to actually fasten to the stabilizers to prevent "push" and "pull" forces?
ProPride Hitch
Old 08-29-2014, 07:36 AM   #9
TURBS's Avatar
Mine had pads on them to.
I had to cut mine down to fit .
I removed and shortened them to fit within the constraints.
Side to side you may be able to get one to wedge in there.
For and aft could be an issue as you'd have nothing for the pad to "push" against.
so with that in mind you could install a push plate on the frame at a predetermined location?
TURBS
Old 08-29-2014, 07:41 AM   #10
I was hoping to use the two cargo bars to go side-to-side (one in front, one in back), and counting on my home-made X-chocks (PT 4x4s with threaded rod and associated nuts/washers) to control front-to-back movement.
If that doesn't work, I may try fastening a stop block for front-to-back. Not into welding, but if I can find a spot where I can bolt on a piece of angle iron, I may do that. Will post some pics if it ends up working out.
Thanks again.
ProPride Hitch
