Old 06-10-2018, 06:32 PM   #481
rollscanardly's Avatar
Not being one to take chances, I decided to install one of these traveling awning lock pins...
So, that's it for now.
I'm getting to the point where I will have to start to figure out what to do to a camper that has been sitting for about 7 years.
Like, should I clean all the tanks out? Fill the water system up, run everything to check for leaks?
I still have to run all the propane appliances to make sure that I know what I'm doing.
This is all brand new to me.
Suggestions welcome!!
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood 5th wheel (in progress...)
2004 Dodge Ram 2500 Quad cab
rollscanardly is offline   Reply With Quote
Old 06-12-2018, 10:34 PM   #482
I think I would try the water system first. Start by hooking up the city water connection to a garden hose. I would use a pressure regulator. See if you have any leaks and if the valves and fasucets work. Once past that test you could put water in the tank with bleach and see if the pump works. Jay
Jay2504 is online now   Reply With Quote
Old 06-13-2018, 04:35 AM   #483
Thank you, Jay. I will do that.
Can you explain using the pressure regulator?
Man...I hope that there are no leaks...
Rich
Old 06-13-2018, 06:37 AM   #484
Rich
The pressure from house or CG water supplies can be quite high sometimes and using a pressure regulator will keep the incoming pressure to the trailer around 40 psi. Being how old the trailer is, you don't want to over pressure the lines and possibly blow out a fitting. If you have leaks at a lower pressure, then you know you have some more work to do.
TheWolfPaq82 is offline   Reply With Quote
Old 06-13-2018, 11:26 AM   #485
B D HOWie's Avatar
Insane 1999 Wildwood repair....pic heavy!
X2 what TheWolfPaq82 said.
I carry two.
One like this:
https://images-na.ssl-images-amazon....Y340_QL65_.jpg
You can see the pressure you are sending to the RV and adjust it. -$36 on Amazon
The second cheaper model is in the event this one breaks and I need to finish the trip before going to the store.
-$13
I use mine even when connected at our house as our pressure is typically 80-100 psi. An RV should be okay 40-60, but I usually adjust mine to 40 when camping and agree that as long as your unit has been unused I would start below 40.
Also, be advised that restricting the flow rate with the bib valve does not reduce the water pressure.
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 08-06-2018, 06:51 PM   #486
This stuff was done a while ago...
I wanted a more secure way to travel without the TV banging around.
I made this white aluminum piece, along with the black bracket...
...and secured it to the ceiling...
...and the bracket to the TV.
Now, we can travel with the TV securely, in the "up" position...
I bought these leveling wedges. many people said that they sometimes move, depending on the surface. So, I added some "snow tires" to them.
Old 08-08-2018, 12:11 AM   #487
And here I thought the lack of recent posts meant you were out camping!
2017 Rockwood Roo 23IKSS
2017 Ford F150
2018 Days Camped: 31 (so far!)
Maman325 is offline   Reply With Quote
Old 08-08-2018, 04:39 AM   #488
Just busy, as usual...
But..we did finally get to go camping a few weeks ago...
Our first trip...FINALLY!!
Rich
Old 08-08-2018, 06:45 AM   #489
old40ford's Avatar
As you know, I have been following you for a good while and I am amazed at some of your inventions. Seems like all of us that work on metal or weld or really inventors/designers at heart.
Great job and I hope you have many, many great days of camping.
John
Retired Auto body teacher/Retired RV Dealer GM
2017 Puma 255RKS
2013 F-150 King Ranch Super Crew 5.0
No Kids
No Pets
But lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 08-08-2018, 09:16 AM   #490
Thank you for the kind words, John!
Cheers ...
Rich
repair, wildwood
