Old 10-07-2016, 10:29 AM   #1
Inside water heater switch
once we got the generator I could see the advantage of an inside switch for better/easier control of when the WH is allowed to come on, when we're on the gen...... wanted a lighted one so it would get more attention and be a reminder that it is on,....... I wanted it in a good visible location, but, the first place I cut to put it, ended up being a "no go",....... when I removed the cutout for the "old work" box, the black tank vent pipe was dead center of the hole(at least now I know where the blk tank vent pipe is),.... will have to cover that with a blank cover plate,.....
now, after every new project, I keep telling myself this has got to be the last thing that needs doing,..... wrong, there is always something else, but at least they are slowing down a little and if I didn't enjoy tweaking the 25KS I wouldn't be doing them anyway,.....
ID:	122326   Click image for larger version
ID:	122327   Click image for larger version
ID:	122328   Click image for larger version
fella10 is offline   Reply With Quote
Old 10-07-2016, 12:26 PM   #2
A handy tip:::: I drill a very small hole first and then use a piece of "stiff" wire to feel if something might be hidden behind wall..You can always fill the hole with matching putty.J
Jim in Halifax is offline   Reply With Quote
Old 10-07-2016, 02:00 PM   #3
"fella10"--I have at times used an oversized blank plate to cover holes such as that one. They come in decorative styles also. Or better yet, find a very thin toggle switch as used to turn on an overhead light in the house if it will fit inside that cut-out. Install that on the hole and let people wonder what in the world it does when they flip it.
Thurman is offline   Reply With Quote
heater, switch, water, water heater
