Old 12-01-2015, 09:29 AM   #1
Installed a digital thermostat on a Dometic Brisk Air II non ducted a/c unit
After giving the dealership a chance to repair my ac unit that had a bad thermostat and when return the unit still would not work properly. I decided to replace my manual control non ducted 13.5k ac unit to have a digital wall thermostat controller. Now the unit will cycle off completely when reaching the set temperature. I really didn't like having the fan running constantly in the bedroom area when running the second ac unit.
Removed the manual ceiling air box and mounting bracket. Disconnect the 120V wires. Had to run 12 volt (battery) wires to the controller at the ac unit for the wall thermostat. Then from the controller at the ac unit run a 3 wire thermostat cable to the lcd thermostat on the wall. Install the new mounting bracket and control box. Connect the 120V wires to the control box. Plug in the 12V wires and connect with thermostat wires. Plug in freeze control sensor to the box and install on bottom left evap coil fins. I just did not installed wiring for the furnace since this is for my bedroom ac unit only.
Ordered the Dometic ceiling air box kit. Model # 3314850.000
Ordered the single zone lcd thermostat control kit. Model # 3313189.000
Attachment 95351Attachment 95352Attachment 95353Attachment 95354Attachment 95355Attachment 95356Click image for larger version
Name:	ImageUploadedByForest River Forums1448983574.235489.jpg
ID:	95357Click image for larger version
Name:	ImageUploadedByForest River Forums1448983592.711142.jpg
2015 Chaparral 360IBL
2006 F350 6.0 C.C./DRW/FX4
carter2k is offline   Reply With Quote
Old 12-01-2015, 09:34 AM   #2
Try posting pictures again. Click image for larger version
Name:	ImageUploadedByForest River Forums1448983894.730659.jpg
ID:	95359Click image for larger version
Name:	ImageUploadedByForest River Forums1448983921.960589.jpg
ID:	95360Click image for larger version
Name:	ImageUploadedByForest River Forums1448983944.871969.jpg
ID:	95361Click image for larger version
Name:	ImageUploadedByForest River Forums1448983964.915780.jpg
ID:	95362Click image for larger version
Name:	ImageUploadedByForest River Forums1448983988.427571.jpg
ID:	95363Click image for larger version
Name:	ImageUploadedByForest River Forums1448984010.671595.jpg
Old 12-01-2015, 10:35 AM   #3
Who Dares, Wins
doc73's Avatar
Very interesting. There had been a thread some time ago about using a relay to activate the ac. This seems much cleaner.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
dometic, led, thermostat
