Old 03-26-2015, 02:09 PM   #1
grumpy0374's Avatar
Installed Furrion Plug Kit
Finally got around to installing a Furrion Plug Conversion Kit to get rid of the "mouse hole" routing. Easy Install. Hardest part...getting courage up to cut 2 1/2 inch hole in side wall. Stud finder and measured three times to make triple sure nothing in way.
Grumpy
ID:	72256   Click image for larger version
grumpy0374 is offline   Reply With Quote
Old 03-26-2015, 02:26 PM   #2
1903wow's Avatar
Looks good!
1903wow is offline   Reply With Quote
Old 03-27-2015, 12:25 PM   #3
Old Enough to Know Better
gasman6674's Avatar
Looks good now you need a 90 degree end to take weight off of it.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 03-27-2015, 01:21 PM   #4
grumpy0374's Avatar
Yup, thats the next purchase. Silly as it sounds, Furrion dosen't make/list a 90 degree adapter with the weather proof screw ring. Looking at a ParkPower/Marinco adapter that looks like it will work.
Grumpy
Old 03-27-2015, 01:22 PM   #5
John McClain's Avatar
sweet job
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 03-28-2015, 12:46 PM   #6
mlarryeliz's Avatar
Nice, you will like it. We have one and we are very pleased with it.
______________________________________________
Larry & Sylvia in South TX
2014 F-150 4x2 Crew Cab EcoBoost 3.55
2015 Flagstaff 26RLWS
Equal-i-zer 1000/10,000
mlarryeliz is offline   Reply With Quote
led
