Old 04-20-2018, 06:28 PM   #1
installing Air horns on My Georgetown
has anyone installed after market air horns? What i am trying to install is a two horn set with two small air compressors to my coaches existing horns. I want to install a nice rocker switch in cockpit area, and when i am on the road switch the rocker switch so that my steering wheel horn will activate the air horns. and be able to switch back to standard horns. here is what I bought
Viking Horns V621K Dual Trumpet Air Horn.
looking if anyone has done this
I have a 2016 Georgetown XL 377TS.
swimref is offline   Reply With Quote
Old 04-22-2018, 08:36 PM   #2
Try these, no compressor needed and very loud.
https://www.amazon.com/dp/B015QEQLL6...v_ov_lig_dp_it
Schwartzworld is offline   Reply With Quote
Old 04-23-2018, 02:14 PM   #3
Failure is my business
2Evil4U's Avatar
I'm running a pair of stebel compact Nautilus air horns on my DD F150. I just used the positive wire that attached to the original horn to power the relays for the new set.
To do what you want, I'd find a switch that has one input and two outputs. Run the horn positive to the input and run from one output back to the stock horn input and from the other output to the new relay input for the new horns. That should work.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
2Evil4U is offline   Reply With Quote
Old 05-22-2018, 03:39 AM   #4
Ninja
To do what you want, I'd find a switch that has one input and two outputs. Run the horn positive to the input and run from one output back to the stock horn input and from the key other output to the new relay input for the new horns. That should work.
Him
PeJa is offline   Reply With Quote
Old 05-22-2018, 03:40 AM   #5
[QUOTE=PeJa;1816623]b
Code:
mi
/QUOTE]
My
N. Kalyn
georgetown
