Old 01-21-2018, 03:48 PM   #1
Ontario camper's Avatar
Installing Awning strip lights
We have a 2013 rockwood 25' mini lite TT. I want to install led strip lighting under the awning, I'm worried about drilling a hole and wondering where is the best spot to drill through the exterior wall to run the wiring through ? Also any suggestions as to what type to get ? We'd like the ones that just plug in to a receptacle in the trailer and work off a remote control. Locations to buy from in Ontario would be appreciated. Click image for larger version
Ontario camper is offline   Reply With Quote
Old 03-18-2018, 12:45 PM   #2
As camping season quickly approaches does anybody have input on this ??
Old 03-18-2018, 01:07 PM   #3
CZNEDY's Avatar
Try boogie lights. They are expensive buy all 12 VDC. If you drill into the wall near the rear door, you can snake the wire down thru the bath wardrobe. I'm not 100% familiar on the inside. Otherwise if you go with the 120 V versions. Just mount the strip and when you set up, connect the remote and the power supply
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 03-18-2018, 01:11 PM   #4
Just as confused as you
Scrapper's Avatar
If you get the 120v type you will most likely have to use an extension cord as the cords for the lights are about 6 ft.
I have a set that is made of 2x 14ft sections with about 20 different light sequences. It runs on a 24vac transformer on the cord with the remote sensor.
Richard & Jill
Old 03-18-2018, 06:30 PM   #5
Is that the dometic ones with the silver remote ?
Old 03-18-2018, 07:02 PM   #6
kho6658's Avatar
Here is what I have installed on the last two Trailers. They stick on with 3M tape. I plug them in when I setup and unplug when breaking down to go home.
https://www.amazon.com/dp/B06XSY4P7P...a-349341462699
2019 Sabre 36BHQ
2017 F350 Lariat
My first
kho6658 is offline   Reply With Quote
Old 03-23-2018, 01:12 PM   #7
The hardest part of installing these is where do you mount the sensor eye?
gmann32 is offline   Reply With Quote
Old 03-23-2018, 01:40 PM   #8
Kaadk's Avatar
I got an RF controller instead and then just mounted the box in the front storage cubby. No need to worry about a sensor eye.
To the OP, I got the strips off E-Bay out of some place in China for dirt cheap, like $10.00 for a 15' roll. I got what I paid for though, as I had one point that the flexing kept breaking the contacts and I had to re-solder multiple times, however, aside from that one joint the rest of the strip has held up beautifully.
Old 03-25-2018, 08:25 PM   #9
Where did you find the RF controller?
Old 03-25-2018, 08:35 PM   #10
Kaadk's Avatar
I got mine also from eBay, but I believe they’ve been spotted on Amazon too.
Old 03-27-2018, 09:34 PM   #11
I bought some led lights from Walmart. They come with true 3m adhesive backing, remote and are 120v house power. We gave $16a set. One set lasted all last season so I got my $16 worth. But they're still on and still working.
Whitaker is offline   Reply With Quote
Old 05-17-2018, 06:57 PM   #12
90% of these 120v led stripes are 12v lit with a converter.. so check the output voltage converter to confirm, then cut the wire to get rid of the converter.. connect to a switch that provide 12v and you are good to go!
Stephan.cote.1 is offline   Reply With Quote
Old 05-20-2018, 07:59 AM   #13
Thanks for info! Got my rf controller and works great! Bought my awning lights at the Webster flea market in Florida! Happy camper now!
awning, light
