03-21-2017, 08:11 AM
Installing exterior tv mount on 31KQBTS
I have a 2017 31KQBTS, and want to install flat tv mount outside just below and to the rear of kitchen window (interior is in open space behind cupboards)
I'm not sure what is between the exterior metal and the finished wall inside (1/2, 3/4 plywood?) does anyone know what they use to frame trailer?
03-21-2017, 08:40 AM
I can guarantee it is not heavy plywood. Is yours metal or fiberglass sides?
I would probably lean towards an interior backing board large enough to cover 2 studs and through bolts.
03-21-2017, 09:11 AM
Metal sides
03-21-2017, 09:31 AM
Unless it was designed to have something mounting there the space is only filled with insulation. You will need to install some sort of backing plate or position your mount directly on one of the wall studs. LED TVs are not very heavy I think my 24" was 6 pounds.
Retired Navy
2016 Flagstaff 26 FKWS
03-21-2017, 09:47 AM
Thank you for the replies. There is plenty of room for a 2'x2' piece of 1/2 or 3/4 inch plywood back plate. Our 48 inch ultra thin tv only weighs 9lbs
03-21-2017, 10:52 AM
With metal siding you will need it on a stud or open the inside and add bracing against the siding as the siding won't handle any pressure
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
03-21-2017, 10:54 AM
Personally I wouldn't do it, maybe hang from a window or skip it
03-21-2017, 12:03 PM
Left Coast
Get you a male/ female rail that's made for outside grill.....That way you can spread the load out
03-21-2017, 03:18 PM
TV mount
Sit it on a table, skip all the holes in the siding, stud locations and problems associated with ir. Put a small table there and park it.
03-21-2017, 03:46 PM
Left Coast
Butyl rubber seals all holes
03-21-2017, 03:48 PM
So does Bondo, but who wants a wall of Bondo holes??
03-21-2017, 03:51 PM
Left Coast
Not everybody looks for the easy way out.....Some use their skills and mine to be different.... Everybody has their own opinion
03-21-2017, 06:34 PM
When I bought my Salem I ask the dealer to install an outside mount. The tech ( a really good one) said it was a bad idea. I trust him so I ran a cable connection to the side and set it on a table. Worked great.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
03-22-2017, 08:09 AM
Left Coast
Wait till the wind blows!.....lol
03-22-2017, 07:43 PM
I had my dealer remove the outside tv bracket before I took delivery. Their body shop repaired the holes. I know, different strokes for different folks, but an outside tv is not camping IMHO.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
