Old 03-22-2014, 09:20 PM   #21
Well the install is done. I will take pictures tomorrow. I ended up running a new circuit with outlet over to that area. Drilled through the floor and ran the wire in conduit. Turned out pretty good. Nice part is when I winterize, the plug is right there to remind me to unplug while turning valves to bypass mode. The anode is in the plug that screws in. It is very small though and I'm not sure on how effective it is. The Hott Rod heater element then screws into that plug. It'll be more clear tomorrow with pictures. I also installed the switch for turning it on and off without having to unplug it every time. The temperature is adjustable as well but is preset to 125 so we will see how that goes. My rig is still winterized as it is cold up here so it will be a few weeks until I can actually test it.
2013 Puma 30DBSS (Parked at Seasonal Site)
2001 Ford F-150
travyp is offline   Reply With Quote
Old 03-23-2014, 02:01 PM   #22
Detailed Pictures of Install
Added a breaker to the panel.
Ran the wires under the camper in a conduit over to the water heater compartment. Had to drill through the floor but sealed it up well with spray foam as well as caulk around the outside.
Screwed the outlet down to the floor.
Thermostat attached to the back of the water heater.
Switch installed so the panel can stay closed and plugged in.
All in all it was a pretty easy project. Would have been nicer had an outlet been close and if I could have gotten up the wall with the switch but didn't see any good alternatives to what I did. Thanks for all the help and looking at the finished project.
2001 Ford F-150
Old 03-23-2014, 02:23 PM   #23
Witch Doctor's Avatar
Very Good, You should work for my dealer, they wouldn't have done it that good..
Coachmen M/H
Concord
2018 / 300 DSC
heater, water, water heater
