Old 12-28-2014, 07:33 AM   #1
Installing satellite dish to a 2011 sunseeker 3120ds
Can a direct tv slimline dish be installed on sunseeker that has no dish now? How difficult? Should I let camping world do it?
wlparr45 is offline   Reply With Quote
Old 12-28-2014, 09:17 AM   #2
Mr. Dan's Avatar
That's a big antenna to be mounted ON a Sunseeker. I fabricated a stand for mine so I can move it around my campsite so as not to be blocked by trees, etc.
Old 12-28-2014, 03:39 PM   #3
Hoglou's Avatar
Tail gate
If you go with a ground level dish (maybe a tailgater) you can use the park coax cable line input in your rear bay and use that line to feed the directv box in the coach. We have a king dome auto lock dish on our sunseeker roof and I keep my directv box in the cabinet over the coach door. We use that same line to push the signal out to an outdoor tv. This line is found on the back of the antenna switch.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 12-28-2014, 09:59 PM   #4
wbdavey's Avatar
I mounted a satellite antenna on the roof of the 5th wheel we had before buying Rocky. That darn thing could always find a tree branch that blocked the signal! Many times we had to move the trailer a foot or two to get a clear signal. If I ever did it again, I'd stick with a portable dish that can be moved to find a clear view of the SW sky.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 12-29-2014, 01:14 PM   #5
Park in the shade not good for mounted dish. Get something you can move wherever you want it.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 12-29-2014, 02:27 PM   #6
buffalohunter's Avatar
X2 get a portable dish!
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
buffalohunter is offline   Reply With Quote
Old 12-29-2014, 03:38 PM   #7
TURBS's Avatar
I'll x 3 this notion!
Old 12-29-2014, 04:26 PM   #8
Mr. Dan's Avatar
I made a satellite antenna base with $11 of PVC, $3 of bolts/nuts and a scrap of board from a volunteer building project. It won't win any awards but it's portable and entirely functional.
Sent (I think)
Old 12-30-2014, 11:32 AM   #9
Attachment 67941
Sent (I think)
If it works don’t knock it. You can get the dish from direct for free and make up a Mickey Mouse base for 12 bucks. It is a heck of a lot cheaper than going to camping world. I made the mistake of putting a roof mount on my 5th wheel and run into the same problems of finding a clear spot, so I end up using a portable antenna about 50 percent of the time.
fasthauler is offline   Reply With Quote
Old 01-09-2015, 09:26 PM   #10
Thanks to all, went with portable dish.
Old 01-09-2015, 10:03 PM   #11
Mr. Dan's Avatar
... and thank you for reporting back!
2011, satellite, sunseeker
