Old 10-14-2015, 07:01 AM   #1
Installing toolbox on TT tongue - couple of questions
There are several posts here on installing a truck toolbox or other similar contraption on the TT tongue to increase outside storage. I'm about to embark on this adventure as well and have a few questions.
My plan:
1. Picking up today (used off Craigslist) a Kobalt aluminum toolbox 60" L x 12" W x 13" D box. Will fit nicely w/o having to move anything on the tongue other than the battery (see below). Fairly light at 30# so not much impact on tongue weight. Will cut a piece of 1/2 or 3/4 plywood to line/reinforce bottom of box.
2. Removing battery/battery box.
3. Installing toolbox between front of TT and the propane tanks/WDH.
4. Re-installing battery inside the toolbox.
5. Moving a bunch of dirty, unorganized stuff (chocks, power cord, water hoses, Anderson levelers, etc) from front pass-through storage to the new toolbox, then reorganizing what remains in the front pass-through storage area so I can actually find stuff.
6. Constantly reminding my wife, my kids, and me to put stuff back where it belongs. . .probably the hardest part of the whole project!
Now for my questions:
1. Bottom reinforcement - should plywood go inside the box or underneath it? I'm assuming inside to protect it and for aesthetics, but maybe there are advantages to putting it underneath???
2. When I re-install the battery inside the toolbox, should I install it inside the existing plastic battery box or just use an automotive fastening clamp to secure it?
3. Venting for the battery - I'm planning on two 2-3 inch louvered vents. I'd planned on placing them to the rear of the toolbox to prevent water/dirt from entering the box. Sound OK?
4. Battery cut-off switch is currently mounted in the side of the plastic battery box. Should I leave it there, or should I mount it to the toolbox for easier access?
5. Any advice on U-bolt size/specs to secure the toolbox to the tongue frame?
6. Finally, the toolbox is bright aluminum. In a perfect world, I'd have gotten a black box but being the tightwad I am, I couldn't pass up the deal on the used box from CL. Any thoughts/advise on possibly spray painting the aluminum black?
Thanks in advance for your input. Once I get started I'll post pictures of before, during, after.
Brian
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 10-14-2015, 02:58 PM   #2
I just did this upgrade a few weeks ago. I purchased a Kobalt toolbox from Lowes (69" x 12" x 13"). It weighs 24 lbs. so not a big addition to the tongue weight. I did keep my "transferred" items lightweight (chocks, blocks, etc.) This did allow me to get rid of one tub inside the trailer :-). I used square 4" x 5" u-bolts from Tractor Supply. The bolts cross under the frame at an angle to increase contact surface. I did not use a plywood floor for support. We drove the length of Alabama and back and have not had any issues. For the battery, I reused the plastic box and secured it to the floor of the truck box using screws, fender washers and Nyloc nuts. I also drilled drain holes from the battery box through the truck box floor. For wiring, I drilled a 1" hole in the back face of the truck box (faces the front of the trailer) and used a PVC pipe elbow and threaded adapter to create a pass-thru and chaffing guard. My truck box is polished aluminum where as my trailer has bronze colored. I don't have an issue with the color difference so I will leave it for now. My fit was tight so I had to shift the propane tanks and cover forward 3/4". The truck box lid was touching the front of the trailer when it was open so I added some foam bumpers at the corners to prevent scratching. I can post pics if you like.
Chris D.
'09 BMW X5 xDrive35D (TV)
'05 Porsche Cayenne (Wife's)
'15 Flagstaff Micro Lite 23LB (TT)
MudyOvl is offline   Reply With Quote
Old 10-14-2015, 03:19 PM   #3
Ejs4029's Avatar
Sure post up some pic's if you can I would like to see them...I'm considering this mod.
Ejs4029 is offline   Reply With Quote
Old 10-14-2015, 03:44 PM   #4
Ford Idaho's Avatar
Just asking, would a 1/4 inch aluminum plate cut to match the box be lighter than plywood?
I would mount the battery in a box of some type to prevent corrosion problems, I see no issue with using the one you now have.
Rust-Oleum Rubberized Undercoating, Black, 15 oz 248657 | Zoro.com
Old 10-14-2015, 05:47 PM   #5
Thanks Mudy! Pics would be great if you have time. Did you do any other holes for venting battery gasses?
Idaho-the spray you put the link in for - have you had good experience with it on aluminum?
Sounds like I may go without plywood unless it feels unstable/weak once I install it.
Thanks all!
ProPride Hitch
Old 10-14-2015, 05:55 PM   #6
Ford Idaho's Avatar
I have only used it on steel.
If properly prepped it should bond well to aluminum.
Old 10-14-2015, 07:15 PM   #7
I would weld up an angle iron frame to sit it on and use a thin sheet of plywood inside to sit the batteries on an protect the bottom.
Old 10-15-2015, 07:02 AM   #8
I just installed a medium Kobalt tool box on our a-frame. Also had one on our previous TT. The box already has vents on both sides of the box. No need for plywood under box. I used the exisiting battery box. Drilled hole on bottom of box for +/- cables and rubber grommet. Used Rust-oleum Rubberized Undercoating on inside bottom of box. Spray painted entie box flat black. I had to replace the hardcover propane tanks cover with a soft cover.
Gary and Jill Winters
Bella - English Cream Retriever
2016 2104s Mini-Light
2014 Silverado 1500
retireclose is offline   Reply With Quote
Old 10-15-2015, 01:17 PM   #9
Here are the pictures I promised.
1) Installed box
2) Foam dots
3) Battery box
4) Square U-bolt
5) Washer plate & Nuts, battery cable ingress
ID:	91629   Click image for larger version
ID:	91630   Click image for larger version
ID:	91631   Click image for larger version
ID:	91632   Click image for larger version
Chris D.
Old 10-15-2015, 01:43 PM   #10
Mr
Nice job. Well done.
gillesgoulet is offline   Reply With Quote
