Old 10-28-2010, 03:26 PM   #31
i got one a month ago and love it. like everyone said he ships fast.
good luck
tommyowen is offline   Reply With Quote
Old 10-28-2010, 08:46 PM   #32
Villa Estate 392FLFB
The_Stuff's Avatar
it looks like a hard drive cooler for computers.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 10-30-2010, 02:47 PM   #33
amarzano's Avatar
Ordered one of these on Thursday. Will pop it into the RV before the next outing.
I assume this is normal - but when we first picked up the RV - Fridge temps would creep up and we had it set on 5. After a that - it seems to have gotten more efficient and we have turned it down to 4..
Let's see if this helps turn it down again..
2011 Berkshire 390BH-60
Cummins ISB 360hp/800ft-lbs DEF
Allison 3000
amarzano is offline   Reply With Quote
Old 11-03-2010, 12:40 AM   #34
Very fast shipping. Good instructions with easy install (less than two minutes).
Just remove the frig light cover, slide the fan bare wire into the 12v female blade connector going to the switch on the frig light, and attach the fan grounding clip to the bare metal fins inside frig. Fan will run whenever the frig is turned on, is quiet and easy to move around into different positions.
Big Vic is offline   Reply With Quote
Old 11-03-2010, 09:45 AM   #35
tmmar's Avatar
I've had one for a few months now but only been on 1 trip with the fan. Can anyone who has one of these tell me how they keep it in place. I put the alligator clip on the cooling fin and put the fan so it was resting on the shelf but while travelling the clip keeps coming off and the fan falls flat.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 11-04-2010, 08:20 PM   #36
I bought one and now I can barely keep the temp above freezing in the frig portion even with the sensor lowered all the way! Might have to disconnect it after cool down.
richdonn is offline   Reply With Quote
Old 11-08-2010, 06:51 PM   #37
miatared's Avatar
I guess the clip you have is weak - try playing with it to see if you can give it more bite somehow. Or try to add a layer to the fin, like a dime or something so the clip has more to hang on to.
Mine stays put, never moved.
Good luck
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 11-09-2010, 05:33 PM   #38
I put double stick 2 sided tape on mine, cut the length of the fan frame, and then split the tape lengthwise down the middle; then stuck half on each of the flat edges, top and bottom. Then, in order to make it fit flat, i wedged the clip in between the fins, it fits in there tight enough to provide a good ground without the need to clamp it. Then just stick it on the fins- I stuck mine centered at the top. Only time will tell if this will stay put when cold and frosty, but it seems to be stuck on there pretty well now! Randy
Old 11-09-2010, 05:45 PM   #39
tmmar's Avatar
Good luck
Received an email from the seller today and he also said that the clip may be weak. He offered to send a replacement but I said that I would like to take additional trips to see if there is still a problem. If there is, I will contact him for a replacement. Very responsive and great customer service.
Tom and Margaret
Old 11-09-2010, 05:56 PM   #40
RV Newbie
buzzards27's Avatar
OK, you sold me
I just bought one, too. His page say 406 units sold to date...
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
fan
