Old 11-09-2010, 06:39 PM   #41
Boyd's Avatar
Repositioning the sensor.
Originally Posted by richdonn View Post
I bought one and now I can barely keep the temp above freezing in the frig portion even with the sensor lowered all the way! Might have to disconnect it after cool down.
Try putting the sensor in the coldest area the sensor tether will allow.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 11-13-2010, 09:11 PM   #42
Originally Posted by buzzards27 View Post
I just bought one, too. His page say 406 units sold to date...
406 units sold on this ad. He has sold 3,200 units with 100% feedback ( Read towards bottom of the ad). DOMETIC NORCOLD REFRIGERATOR FAN FOR RV 12 VOLT: eBay Motors (item 250677760674 end time Dec-02-10 14:37:30 PST)I bought mine 3 years ago when I had my Mh. Great customer support, he will answer any questions you have. My friend bought one and his model did not have hot 12v at light. The seller offered him full refund with shipping included. However the seller sent him pics how others had done it where there was no hot 12v at light, they simply run a 18 gauge 2 foot piece wire down the drain tube to the back of the refrigerator, this worked great.
Mine always stays where I clip it, always keeps ice off of the fins. Humidity is what ices up fins causing refrigerator fins not to extract heat from box, and and ice on the fins makes thermistor that's mounted on fin to think its cold and keeps refrigerator from running. This fan prevents the ice build up.
Great item every camper should have, I bought a spare so when mine quits I will have it. Mine is 3 years old and going strong.
toobus is offline   Reply With Quote
Old 01-10-2011, 07:18 PM   #43
kalik282's Avatar
For those that aren't afraid of a little modification, here's a link to the "original" product. (MassCool 4B02S4 Hard Disk Cooler). Cheaper @ $4.99 & $1.99 shipping, but you will have to cut off the Molex plug & install the ground clip...
Newegg.com - MASSCOOL 4B02S4 Hard Disk Cooler
kalik282 is offline   Reply With Quote
Old 01-11-2011, 10:42 PM   #44
Iggy's Avatar
You get points for finding this on NewEgg. This is exactly what this guy is selling on Ebay for a lot more.
Old 01-12-2011, 10:48 AM   #45
Willybgh's Avatar
Could someone enlighten me with either pictures or description on how the fan is secured? If I get the fan from New Egg or another computer supply place, it will no doubt need to be modified right?
Thanks...
Chris
Willybgh is offline   Reply With Quote
Old 01-12-2011, 10:55 AM   #46
Iggy's Avatar
Thanks...
Chris
I've looked at the picture closely and it may not be much other than a paperclip device or just a hole in one fin and a plastic wire tie.
The objective to to just have air movement over the fins.
The fans seem not to be that reliable so I will wait and watch.
Let us know if you find out more.
Old 01-12-2011, 12:49 PM   #47
CLASS "A" Senior Member
cfsoistman's Avatar
Thanks...
Chris
The one from Ebay stays in place with the alligator clip that is attached to a fin to create the ground to power the fan.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-12-2011, 01:59 PM   #48
Willybgh's Avatar
Please excuse my ignorance on this as I want to make sure I have it right.
Did you mean that the alligator clip is perminently attached to the fan and this then clips on the fin in the back of the fridge? Does the fan weight not make it fall off when traveling?
I just want to make sure that if I get one that I know how to modify it properly.
Thanks....
Chris
Old 01-12-2011, 02:41 PM   #49
tmmar's Avatar
Chris,
Yes- the alligator clip is permanently attached and it is the clip that holds the fan in place. The one on ebay has one of the clips jaws covered in soft vinyl that more or less keeps it from slipping. You need to rest the fan on the shelf to support it and make sure that it doesn't slip off.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 01-12-2011, 04:53 PM   #50
Willybgh's Avatar
Originally Posted by tmmar View Post
Chris,
Tom
Thanks Tom.
That helps. And I just have to run the one wire to the fridge light.
Chris
fan
