Old 01-12-2011, 05:37 PM   #51
tmmar's Avatar
Originally Posted by Willybgh View Post
Thanks Tom.
That helps. And I just have to run the one wire to the fridge light.
Chris
Chris,
Yes- to the hot lead of the light.
Tom and Margaret
2014 Berkshire 390bh-60
Old 01-12-2011, 08:57 PM   #52
I bought one off ebay and it really made a difference. I just cliped it to fin and let it hang in front of fins and have not had any issue of it falling. And no it is not resting on the shelf.
slides is offline   Reply With Quote
Old 01-14-2011, 10:12 AM   #53
I bought the one from ebay. Looked like a simple, well thought out unit. Tried it in my fridge and it dropped the temp only 1 degree.
Waste of money for me!!
MacDaddy is offline   Reply With Quote
Old 01-14-2011, 03:32 PM   #54
RV Newbie
buzzards27's Avatar
i deployed my fan this fall and found a 10 or 15 degree drop in tempature. I ended up with a fridge that was near freezing if the door wasn't opened very often. you may find that there is a greater change in the summer months or longer trial.
not sure what time period you used to quantify that one degree drop. you have to give it time to work, just as you have to give the fridge plenty of time to cool. you might be misunderstanding the purpose of the fan. it is meant to limit the buildup of frost on the fins by circulating air inside the fridge. in doing that i think it makes the fridge more efficient.
i mounted my fan toward the top of the fridge, clipping the ground clip to the very top of the fins and using a little 29 cent home depot clip clipped to the fin below the fan base to hold it in place.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 01-24-2011, 07:45 AM   #55
Originally Posted by kalik282 View Post
For those that aren't afraid of a little modification, here's a link to the "original" product. (MassCool 4B02S4 Hard Disk Cooler). Cheaper @ $4.99 & $1.99 shipping, but you will have to cut off the Molex plug & install the ground clip...
Newegg.com - MASSCOOL 4B02S4 Hard Disk Cooler
I took the above link and built my buddy one Saturday and I will not do it again.
Fan $7.80 from above link, fan + tax + shipping. A package of alligator clips Wally World $1.50, 18 gauge wire 15 ft roll $4.47 Lowe's, picture hanger wire $2.97 roll (its floppy) wally world.
Ive spent $16.74 plus used a better part of my Saturday putting the dang thing together. $17.59 on Ebay and I don't put it together. Saved a Grand Total of $0.86 !!!!
Did I mention running to wally world / lowes on $3.25 gal of gas. Opec S**KS!!!!!
toobus is offline   Reply With Quote
Old 01-24-2011, 08:04 AM   #56
CLASS "A" Senior Member
cfsoistman's Avatar
The fellow on ebay also has a good reputation for resolving any problems you may encounter. It's a deal if you already have the other items needed already at home but if not then as you stated the costs add up. Thanks for all the info you provided.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 01-24-2011, 10:11 AM   #57
He must have sold out. It says removed from E bay? Youroo!!
Old 01-24-2011, 10:17 AM   #58
RV Newbie
buzzards27's Avatar
you could easily cut the cost of the fan itself. I suspect I could find a handful of similar fans in the half dozen old 'puters I have in the basement. LOL, I still have a 386DX down there. you could visit a shop that puts puters together, they'd probably have the fans and would probably have all the other parts you need on the shelf.
Old 01-24-2011, 12:25 PM   #59
cfsoistman's Avatar
Not sure where you were looking but here's the link to the fan.
DOMETIC NORCOLD REFRIGERATOR FAN FOR RV 12 VOLT - eBay (item 250677760674 end time Jan-31-11 14:37:30 PST)
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-24-2011, 01:32 PM   #60
Originally Posted by cfsoistman View Post
Here's a link to it at Ebay.
DOMETIC NORCOLD REFRIGERATOR FAN FOR RV 12 VOLT: eBay Motors (item 250664662559 end time Aug-10-10 06:12:12 PDT)
Guess what I just did. Yep bought 1.
Thanks NWJeeper!!!!!!
This is the one I clicked on,but I used your site and it worked fine ,Thank you! Yoyroo!!
fan
