Old 04-04-2011, 07:11 AM   #81
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Wow! I will have to try one of these fans... the little cheapy battery fans are $15+ dollars if this works... worth the $$!
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 04-04-2011, 10:28 AM   #82
Thanks!! I just ordered one. Perhaps you should be getting a sales comission.
peskin is offline   Reply With Quote
Old 04-08-2011, 09:53 AM   #83
So what does the fan do for you? Cool it down faster? I have a problem sometimes with my refrigerator needing to be defroster fairly often, maybe every 3 weeks. Will it help with that?
georgetown50 is offline   Reply With Quote
Old 04-08-2011, 10:31 AM   #84
Boyd's Avatar
The cold air from the fins is better circulated with the fan and will keep the ice build-up, behind the fan, from the fins. It will NOT defrost your freezer compartment.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 04-08-2011, 10:33 AM   #85
miatared's Avatar
RV fridges are condenser type and thus have no air movement at all inside.
So anything that can be done to help with air circulation is a good thing.
Yes it will help with cooling, and help with preventing ice build up on the cooling fins.
One can use just about any 12V fan, like a computer case fan, you need to find a 'hot' wire at the light to power it - to make sure it stays on with the door closed.
This one looks cool in blue, 2 little fans and it improves everything all around and it cost less tha 3 gallons of gas
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 04-10-2011, 08:08 AM   #86
sherdep's Avatar
I bought the fan at CompUsa for $6.99 ($7.48 with tax)
Now I just need to put the alligator clips on the fan wires
Stupid question and I know it was said somewhere in this thread but dont want to re- read the whole thread, can you post a pictures of the back side of the fan or does it have another alligator clip to hold it inside the fridge on the fans?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-10-2011, 12:53 PM   #87
I got one and it works very well
jutojohn is offline   Reply With Quote
Old 04-14-2011, 09:40 PM   #88
got mine today (shipped super fast btw). i hooked it all up and i was expecting the fans to blow the air away from the fins. my fans are blowing straight into the fins. is this how it is supposed to be?
2006 Cherokee Wolfpack 295WP - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Starlight Revolution 300 lumen LEDs EVERYWHERE!
2012 Dodge 2500 - deleted and tuned by H&S performance
Bocephus is offline   Reply With Quote
Old 04-16-2011, 11:56 AM   #89
Yes, it recirculates the air back across the cold cooling fins, cools the air and the air keeps the fins dry. Twice the bang for the buck!
toobus is offline   Reply With Quote
Old 04-16-2011, 03:08 PM   #90
Another option for a fan is a fan specially made to circulate the air inside the fridg and sold by Camco. It uses 2 D cell batteries and will run for a full month before they runs down. On this fan you have a charcoal filter sachet that you can replace on a monthly basis. This fan dont take much room and it is extremely quiet. The price also is very quiet at $17.95.Canadian and in US it will probably cost less than $15.
capucine is offline   Reply With Quote
fan
