Old 08-23-2014, 02:56 PM   #11
VinceU's Avatar
Originally Posted by Big Vic View Post
My microwave is rated 900 watts - but that is output...wattage input is almost twice that. It draws about 1750 watts off the 2000w inverter while running. I use 4 6-volt golf batteries in pairs with 4/0 welding cable to handle the 145 amps pulled out of the batteries.
While running the microwave, the voltage of the batteries goes from 12.6 to 11.8, but then right back up to 12.6 when microwave done.
With all that battery capacity to maintain, why not get a small portable M/W with half the capacity and 1/2 the power requirement? Just thinkin?
Old 08-23-2014, 03:11 PM   #12
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
If you want to be able to run your electronics 24/7 I would suggest a smaller psw inverter plus a larger one dedicated for the microwave because even on standby the inverter will draw quite a bit of power from the batteries and there is no need to run a 2000 Watt inverter to charge an iphone.
Xantrex and Samlex are definitely proven brands.
Psw inverters do cost more initially but deliver cleaner power and appliances that tolerate msw power operate more efficiently on a psw inverter and oftentimes last longer.
But everyones setup and requirements are different.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 08-23-2014, 04:18 PM   #13
I installed this one. 1000 watts and wireless remote on and off. So far works great. I use the honda 2k generator for the microwave.
Name:	ImageUploadedByForest River Forums1408828665.263313.jpg
Name:	ImageUploadedByForest River Forums1408828682.622362.jpg
Name:	ImageUploadedByForest River Forums1408828697.017895.jpg
Trailer plugs into the inverter from outside outlet.
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
inverter
