Old 08-12-2015, 09:59 AM   #11
jeepman71's Avatar
Originally Posted by mud yapster View Post
Here's my inverter I put in.
Attachment 85402
Mud yapster
This looks like it is on the path to what I am wanting to do. The idea of plugging the cord into the inverter is a quick and simple install but every time I use the inverter I will need to hook up the cord and make sure I have heavy draws turned off.
What do you have going on? I can't tell for sure with the picture.
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
Old 08-12-2015, 10:05 AM   #12
ironj's Avatar
This is how mounted mine in the front
..I had an outlet in the front br that was powered...or if I wanted back tv/outlets I would plug in shore cord and flip off all the breakers except the outlets... worked great, but only really used it once before I sold trailer... (inverter is for sale in classifieds)..
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 08-12-2015, 01:09 PM   #13
Here is a thread on how I did it!
inverters and wiring mod
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 08-12-2015, 06:34 PM   #14
bikendan's Avatar
Originally Posted by MarsMan View Post
I would like to do the same as this and have a couple of questions.
i assume this is just a regular run of the mill inverter?
You hooked directly to the batteries and not onto the power bar controlled by the battery master switch for the trailer? There is a light to remind you to turn off?
Did you install an inline fuse between it and the battery or does the inverter have a breaker?
Yep, run of the mill 400w inverter.
Added my own battery disconnect switch. The inverter has its own lighted power switxh.
Inverter came with its own internal/removable fuse.
I went straight to the battery because it was a much simpler path, than going to the breaker/fuse panel.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-12-2015, 07:04 PM   #15
ironj's Avatar
I wired up a second battery on the tongue. .then ran those to a dual battery isolator switch...
The power went from there to an 80 amp fuse (mine is a 1000w inverter)..then to the inverter. You want that power cable as short as possible.
This particular inverter has a key fob so you can turn the inverter off/on remotely..
inverter
