Old 08-05-2015, 12:17 PM   #1
jeepman71's Avatar
inverter install
I have a 2014 Wildcat 317RL. I would like to install an invertor to control the plug for the entertainment center and the outlets on the wall by the couch. These outlets are on the same circuit as the GFCI in the bathroom and an outlet on the end of the peninsula in the kitchen. What would be the safest setup and the most economical setup. I don't need alot of watts just enough to run the tv and the pump for the air mattress in the couch.
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
Old 08-05-2015, 01:07 PM   #2
bikendan's Avatar
i just hardwired my inverter to the batteries and mounted it on the side of the cabinet, where the tv hookups were, since all i wanted it for was tv, dvd and charging electronic devices.
no need to go to all the trouble of a more complicated install.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-05-2015, 08:53 PM   #3
anyone install an invertor in front storage area of 5er......Thought I would plug in my "beer" fridge when en route to our camp site....J
Jim in Halifax is online now   Reply With Quote
Old 08-05-2015, 08:59 PM   #4
Who Dares, Wins
doc73's Avatar
If you Google love your(might be ur) rv, this guy did a good video / blog post of an inverter install in his 5er using an inside plug and a 1000 watt inverter.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 08-12-2015, 08:03 AM   #5
Mount the inverter as close as possible to your batteries, using large gauge cables. Then run a standard 120v cord from the inverter to your entertainment center. If you want, you can terminate that cord into a 120v receptacle.
I simply plug my 2000w inverter into the TT's 30a outside shore side input, so that all my inside 120v receptacles are powered.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-12-2015, 08:14 AM   #6
I assume you shut off the converter when hooking this up?
sugarjohnson is offline   Reply With Quote
Old 08-12-2015, 08:20 AM   #7
jeepman71's Avatar
I would like to hook the inverter to the breaker that runs the entertainment center, living room area and kitchen and have that switch between shore power and inverter via a switch near the breaker panel. I have heard of people running this through a hot/off/hot switch and wonder how well this would work. I don't need help wiring, I am looking to not reinvent the wheel.
Old 08-12-2015, 08:45 AM   #8
mud yapster's Avatar
Here's my inverter I put in.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-12-2015, 08:46 AM   #9
MarsMan's Avatar
I would like to do the same as this and have a couple of questions.
i assume this is just a regular run of the mill inverter?
You hooked directly to the batteries and not onto the power bar controlled by the battery master switch for the trailer? There is a light to remind you to turn off?
Did you install an inline fuse between it and the battery or does the inverter have a breaker?
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 08-12-2015, 09:01 AM   #10
Fulltime family RVer
This is what I want to do, only mine is in the very back in a slide.
Interesting- I didn't think of it that way.
X2
inverter
