Old 11-30-2015, 06:36 PM   #11
Hmmm...I think this thread just put me steps backwards lol
jjlavin is offline   Reply With Quote
Old 11-30-2015, 09:00 PM   #12
Evereddie's Avatar
Originally Posted by jjlavin View Post
I looked at some of the components and they have an input and output rating. Your cell phone example is the output. So I don't need to care about the input part? Just output?
In all reality the input specs are the ones that are most accurate but in these cases there is little difference between the 2. The difference between the input power and output power is called efficiency.Efficiency of the device means it takes a little more input power to 'make' the output power. Some is wasted as heat but the difference is so minor in this low power stuff it really comes out the same., Most of these devices are around 95% efficient so just give a little extra when you use the output power. The inverter itself is 90- 95% efficient too.
Evereddie is offline   Reply With Quote
Old 12-01-2015, 05:40 PM   #13
I finally replaced the fuse for the cigarette lighter on my 335DS today (it is right behind the receptacle under the dash. Wow...7.5 amps. No wonder it always blows. That would be a total wattage of 90 watts, including losses from the inverter itself. Forget the 150 watt units...they will just blow your fuses!!!!
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 12-02-2015, 04:47 PM   #14
I hope you didn't put a bigger fuse in without checking the wiring between the lighter socket and fuse panel. Fuse size has to be calculated to protect the wiring as well as the device on the circuit. 18 gauge wire would normally be rated at 7.5 amps.
If the lighter itself is rated to 15 amps, you need 14 gauge wire to support 15 amps (and a 15 amp fuse) without overheating. Note that even a 15 amp circuit will only power a 175 watt maximum input inverter.
Fred W
the one who managed to start an electrical fire with paralleled 12V batteries and 6 gauge cables
2014 Rockwood A122 A-frame (now with 6V golf cart batteries!)
Old 12-02-2015, 04:54 PM   #15
Actually to the contrary. I didn't have a 7.5 and with only 20,15,10 and 5 to choose from, I used the 5!
2015 335DS
Old 12-06-2015, 09:34 AM   #16
Jjlavin: what are you trying to run?
Kuba is offline   Reply With Quote
inverter
