Old 02-17-2016, 12:21 PM   #11
B and B's Avatar
Is your Hot Water heater turned on electric?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-17-2016, 12:24 PM   #12
Who Dares, Wins
doc73's Avatar
Also make sure your convertor is off.. It makes a crzy loop when the batteries power the invertor then the invertor powers the convertor... But I would first shut everything off and see what happens with just one circuit at a time to see what trips the system.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 02-17-2016, 12:48 PM   #13
Havasu Bill's Avatar
I had the water heater on the fist time when it kicked the fuse. I turned it off and got the same result.
Ok, dumb question, how do I turn the converter off?
Bill
2016 Forest River 3250 Cardinal
2016 RAM 2500 Longhorn
Previously: 36' Country Coach
Havasu Bill is offline   Reply With Quote
Old 02-17-2016, 01:34 PM   #14
Who Dares, Wins
doc73's Avatar
There will be a breaker for it on the main panel, prob labeled as convetor or conv. That is what makes the 12v power from the 120 volt.
2015 ChevyHD D-Max
Old 02-17-2016, 01:48 PM   #15
Thanks! I'll have a look 😊
Bill
Old 02-17-2016, 04:26 PM   #16
Found the breaker and that did the trick. I can run the fridge, TVs and lights. I tried the coffee machine but that kicked it off again.
I guess I need a bigger inverter to make coffee and run the microwave.
Old 02-17-2016, 06:12 PM   #17
Who Dares, Wins
doc73's Avatar
2000 watts will be close. They are prop 1500 watts maybe a bit more. Try turning everything else off and see if they can be run. Just one at a time.
2015 ChevyHD D-Max
Old 02-17-2016, 07:10 PM   #18
Thanks! I'm headed out on a trip with it in the morning. Hope to have more time, when I'm not playing in the sand dunes, to mess around more with it.
Thanks for the quick help getting it to work. I've got a tech coming on Monday to give me recommendations on a long term fix.
Old 02-18-2016, 07:32 PM   #19
Everything is working great running the "jumper" from the 2000W inverter to the shore power receptacle.
I've got an 80A Optifuse in the positive feed to the inverter. If I'm reading my Cantrex Prowatt manual correctly it says I can have a 250A fuse there. It's the 80A that kicks limiting the inverter output.
Has anyone replaced this fuse or have any other thoughts?
Tomorrow morning I'm testing the coffee maker again 😊
Old 02-18-2016, 08:13 PM   #20
Who Dares, Wins
doc73's Avatar
I would not do a 250 amp.. 166 amps would make your max output 2000 watts. I'd do a 150/ 155 amp breaker to leave some wiggle room.
2015 ChevyHD D-Max
inverter, wiring, modifications
