Old 05-24-2014, 09:27 AM   #1
Road-King's Avatar
Jack pads
I got tired of my 2X12's splitting. Found this idea on utube.
I bought a 4X6 horse stall mat at Tractor Supply for $40, cut it up into 24 12X12's. Gave 12 to my FIL and I use 12 under my 6 point level up jacks. Seems to be working good. They are rubber, made from recycled tires.
Sent from my SCH-I535 using Forest River Forums mobile app
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 05-24-2014, 04:17 PM   #2
Iggy's Avatar
That is a great idea! Good thinking.
Now as a city slicker I'm guessing a horse stall matt is a hard rubber or plastic mat.
Are they very heavy?
Old 05-24-2014, 04:29 PM   #3
Ford Idaho's Avatar
I made a set of four last week from 2x6 boards sandwiched between 1/4 in plywood.
Glued and screwed the lot together and then coated the works with some Flex Seal and then screwed rope handles on.
I am not sure how they will work out so I am going to try you idea next.
Old 05-24-2014, 07:54 PM   #4
Road-King's Avatar
Hard rubber. The mat weighs 100 lbs. Easy to cut with a metal straight edge and a box cutter knife. Went through 3 blades.
Russ & Kim
2014 Alpine 3600RS
Old 05-24-2014, 08:04 PM   #5
Ford Idaho's Avatar
Jig saw would be my choice may lube the blade with some soapy water.
One of three.
Old 05-24-2014, 08:14 PM   #6
Who Dares, Wins
doc73's Avatar
Use walmart plastic cuting boards for our pads. Light weight and stiff enough. Being out here in Amish country never thought to use the horse mat...
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-24-2014, 08:41 PM   #7
VinceU's Avatar
At 1/2 for mat, that's 50 lbs. Pretty expensive in lost cargo ability.
VinceU is online now   Reply With Quote
Old 05-24-2014, 09:05 PM   #8
Just covered a Lynx block with alum tread plate top and bottom and bolted to pad. Don't have to store anything.
ID:	53226   Click image for larger version
Name:	Front landing jak pad.JPG
ID:	53227   Click image for larger version
