Old 07-13-2011, 06:24 PM   #1
M109Rrider's Avatar
Jack TV OA 8201 antenna install
Done deal. Replaced the Jensen omnidirectional TV antenna with a Jack TV antenna. Mounted it right over where the Jensen was. It was only a 2 beer job, pretty easy.
Step 1: Follow the supplied directions
Really that's the easiest way I could tell you to do it, they're well written. Can't tell if it's any better or not at home. We can get a ton channels using vice grips and a clothes hanger here. Our campground this coming weekend doesn't have cable so I'll report back next week.
ID:	6798   Click image for larger version
ID:	6799   Click image for larger version
ID:	6800   Click image for larger version
ID:	6801   Click image for larger version
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 07-13-2011, 06:33 PM   #2
M109Rrider's Avatar
Here's a link to the directions http://www.kingcontrols.com/userfile...2011-11-10.pdf
Jason and Billie
Old 07-13-2011, 07:55 PM   #3
grhodes50's Avatar
Looks good. Keep us posted on how the antenna performs.
The problem I would have with my 303RKS is the location inside the tt. (see pic) I would have to do some remodeling of the center cabinet above the tv since the Jensen is directly above and inside the cabinet.
Otherwise I would have to relocate the antenna location, which I really don't want to do.
Gary & Trish
2018 Nights Camped - 5
Old 07-13-2011, 08:13 PM   #4
M109Rrider's Avatar
I had about 5 feet of extra coax stuffed in the ceiling. The new antenna base has a slot in it to run the coax through if it's coming in externally. The hole in roof was only about 3/4" in diameter for the coax to go to the jensen. You could seal the hole around the coax and mount your antenna back further. That section of coax would just be laying on the roof. You could always cover it with that eternabond tape to hide it a little if you wanted.
Jason and Billie
Old 07-13-2011, 08:16 PM   #5
M109Rrider's Avatar
Is the top of that cabinet just the ceiling? If so you could you mount the control knob inside the cabinet.
Jason and Billie
Old 07-13-2011, 08:23 PM   #6
grhodes50's Avatar
That would probably be better than tearing up the cabinet. Like you said, just use Dicor around the hole then Eternabond everything.
I'll have to think on this awhile. If I decide to do it I'll only get one chance at it, right?
Gary & Trish
Old 07-13-2011, 08:29 PM   #7
Question
Jason, how tall is the antenna?
I'm glad it was only a 2 beer job, I'd hate to see you fall off the trailer .
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 07-13-2011, 08:31 PM   #8
grhodes50's Avatar
Yeah it is and that's another possibility. What size is the Jack ceiling mount?
The cabinet is shallow and measures 21Ĺ" wide by 8" deep.
P.S. Just went out for a quick look. Just from eye balling it, the Jensen looks to be centered over the doors of the cabinet. Would I be able to "offset" the Jack about 4" so the ceiling mount would fit sideways inside the cabinet? That is if it will fit at all.
Gary & Trish
Old 07-14-2011, 04:27 AM   #9
M109Rrider's Avatar
just shy of 1 ft.
Jason and Billie
Old 07-14-2011, 04:37 AM   #10
M109Rrider's Avatar
the base of the Jack is quite a bit larger than the base of Jensen, you may be able to move it that much, tuff to say. The inside piece is about 4X8". You can mount this piece any direction you want, it doesn't matter.
Jason and Billie
antenna
