10-09-2015, 02:33 PM
JT strong-arm stabilizers - T-handle bolt thread ?
I'm wanting to order some BAL lock-arm stabilizers (just because they can be bought in individual pairs, rather than just as a full set of 6 like the JT's etc), however I'd like to use T-handle bolts like the JT's have.
I found these on amazon: -
http://www.amazon.com/gp/product/B00...=sr_1_4&sr=8-4
Does anyone know (or could check) the thread-size of the T-handle bolts on the JT strong-arms ?
BAL were kind enough to inform me that the bolts in their Lock-arm stabilizers are 1/2" - 13 thread count. I'm hoping that the JT bolts might be the same, so I could use them with the BAL. (I haven't managed to find any other T-bolts with a 1/2"-13 thread)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
10-09-2015, 02:40 PM
I assume you have a friend with a welder somewhere. Couple of bolts of the appropriate size...after cutting. Tadaaa. You got some. I would do it for you and I don't even know you.
JMO
2017 Puma 297RLSS
10-09-2015, 02:56 PM
JMO
Appreciate it, may even take you up on the offer (with some remuneration)
Unfortunately I don't have any welding gear anymore, and I can't think of anyone particularly local with a welder, but I will ask around
Don't mind paying a little bit for the solution, which is why I was considering something "off the shelf"
10-09-2015, 03:18 PM
Originally Posted by leefl
... (I haven't managed to find any other T-bolts with a 1/2"-13 thread)
Just take them to a welding shop and have them weld a pc of 1/2" rod on top of the existing handles.
10-10-2015, 11:39 AM
After loosing one I ordered some spares direct from JT. You might give them a call.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
10-10-2015, 12:10 PM
I went to Graingers and bought knobs with the correct bolt size built in.....
10-10-2015, 02:19 PM
I can get the t-bolts from JT, but I want to check first if they'll fit in the BAL stabilizers
10-11-2015, 01:59 AM
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
10-11-2015, 09:59 AM
Originally Posted by SimchaSabre
Thanks, just what I needed to know. I found the Amazon link to them but didn't see the size mentioned there.
If they're 3/8" then I'll have to make something up, or find something elsewhere since the threads for the BAL ones are 1/2"-13
10-11-2015, 10:04 AM
My homemade L shaped ones are 1/2-13. Made them L shaped so they would not have a tendency to loosen on their own with the L and gravity keeping the heavy end down.
10-11-2015, 10:13 AM
Nice idea, just need to make sure the bar is to the right of vertical, if upwards, I guess so the weight pulls it tighter, not looser
10-11-2015, 10:26 AM
Had both do yourself a favor and look into steady fast system there's no preload super easy
Mainy so they don't move while in transport position, I don't tighten them in the transport position because having CRS, I would most likely try to extend the jacks with the stabilizer tubes tight.
10-11-2015, 10:28 AM
And throw away perfectly functional, time tested homemade ones?? Don't think so.
10-11-2015, 10:51 AM
If I were still at work, I would have used our lathe and made 3/8 - 1/2 reducing bushings. But now that I am retired and my time is more valuable, I'd try to find some long 1/2 bolts and bend them to L shaped as Old Coot suggested.
I haven't lost any T handles from my JTs yet but the do move in travel. I have several spares, but I actually thought about cutting one side of the Tee off and let gravity help.
Cathy & Jeff
Midland, Michigan
10-11-2015, 11:15 AM
I just used a 1/2" bolt and welded a pc of 1/2" rod on the head of the bolt.
10-11-2015, 08:57 PM
Whadya mean by "preload" for the other stabilizers?
