Old 10-09-2015, 02:33 PM   #1
leefl's Avatar
JT strong-arm stabilizers - T-handle bolt thread ?
I'm wanting to order some BAL lock-arm stabilizers (just because they can be bought in individual pairs, rather than just as a full set of 6 like the JT's etc), however I'd like to use T-handle bolts like the JT's have.
I found these on amazon: -
http://www.amazon.com/gp/product/B00...=sr_1_4&sr=8-4
Does anyone know (or could check) the thread-size of the T-handle bolts on the JT strong-arms ?
BAL were kind enough to inform me that the bolts in their Lock-arm stabilizers are 1/2" - 13 thread count. I'm hoping that the JT bolts might be the same, so I could use them with the BAL. (I haven't managed to find any other T-bolts with a 1/2"-13 thread)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 10-09-2015, 02:40 PM   #2
Iwannacamp's Avatar
I assume you have a friend with a welder somewhere. Couple of bolts of the appropriate size...after cutting. Tadaaa. You got some. I would do it for you and I don't even know you.
JMO
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 10-09-2015, 02:56 PM   #3
leefl's Avatar
JMO
Appreciate it, may even take you up on the offer (with some remuneration)
Unfortunately I don't have any welding gear anymore, and I can't think of anyone particularly local with a welder, but I will ask around
Don't mind paying a little bit for the solution, which is why I was considering something "off the shelf"
Old 10-09-2015, 03:18 PM   #4
Originally Posted by leefl View Post
... (I haven't managed to find any other T-bolts with a 1/2"-13 thread)
Just take them to a welding shop and have them weld a pc of 1/2" rod on top of the existing handles.
Old 10-10-2015, 11:39 AM   #5
Telstar's Avatar
After loosing one I ordered some spares direct from JT. You might give them a call.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 10-10-2015, 12:10 PM   #6
I went to Graingers and bought knobs with the correct bolt size built in.....
Bob Vaughn is offline   Reply With Quote
Old 10-10-2015, 02:19 PM   #7
leefl's Avatar
I can get the t-bolts from JT, but I want to check first if they'll fit in the BAL stabilizers
Old 10-11-2015, 01:59 AM   #8
JT T Bolts =3/8 " thread:
Amazon.com: Lippert Components 314594 Jack Stabilizer Replacement T-Bolt: Automotive
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 10-11-2015, 09:59 AM   #9
leefl's Avatar
Originally Posted by SimchaSabre View Post
Thanks, just what I needed to know. I found the Amazon link to them but didn't see the size mentioned there.
If they're 3/8" then I'll have to make something up, or find something elsewhere since the threads for the BAL ones are 1/2"-13
Old 10-11-2015, 10:04 AM   #10
My homemade L shaped ones are 1/2-13. Made them L shaped so they would not have a tendency to loosen on their own with the L and gravity keeping the heavy end down.
stabilizers
