Old 12-20-2015, 08:26 PM   #21
dcheatwood's Avatar
Had them on my wildcat and they made a huge difference in stability/shake. Did not get them on current rockwood just to keep weight down.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 12-20-2015, 09:29 PM   #22
I had them on my rear jacks and used BAL X chocks as well. Got tired of messing with them. Just took them off and tossed them this Summer. They were pretty well rusted up from non use. Quit using the X Chocks as well. Now I just use large yellow chocks by my wheels. I can't say that I notice much if any difference. Maybe I'm just getting used to it...
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 12-20-2015, 10:39 PM   #23
New to FR. Old to TT
i have a 85lp gsd that would chase the cat or a ball from back to front and would bounce our tt with just using elec jacks and the hitch jack. then I put 2 bottle jacks under the frame between the wheels and just raised the frame enough to take some weight off the tires. took a bit of trial and error for right amount of lift so as to not lift off stabilizing jacks, but when stopped all the bouncing. good luck
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
Tall frog is offline   Reply With Quote
Old 12-21-2015, 07:07 AM   #24
dj3spots's Avatar
Having them installed in the spring. Think they're worth it.
dj3spots is offline   Reply With Quote
Old 12-21-2015, 06:30 PM   #25
Absolutely!
robertb152 is offline   Reply With Quote
Old 12-21-2015, 08:21 PM   #26
Steelframer's Avatar
My TT felt like a 'ship at sea' whenever anyone moved about. After putting on the 'strong arms **' there is very little movement at all, and I highly recommend them.
** I built my own, not difficult at all,,, but you will need access to a welder.
TT-2015 Cherokee 274dbh TV-2011 Ram 3500 Longhorn Limited
Steelframer is offline   Reply With Quote
Old 12-28-2015, 06:09 PM   #27
Michael4017's Avatar
JT's were delivered today. Installation looks straight forward. Will wait for warmer weather to do the install.....can't wait!
'16 Cherokee 274DBH
'09 F150 Supercrew
Mike
2016 Cherokee Limited 274DBH
2016 Ford F-150
Michael4017 is offline   Reply With Quote
