Old 10-19-2015, 08:14 AM   #1
TURBS's Avatar
Jt strongarms and 4 point autolevel.
Has anyone installed jt strongarms on there 4 point "6 jacks" auto leveling system?
2) jacks in the front. "Leveling"
2) jacks in the middle "stabilizing"
2 jacks in the rear "leveling"
If so how did you install the rear arms on the jack?
To do it correctly you would need 4 more bronze bushings and two more u clamps such as the ones used in the front .
Called lippert this morning and both gentlemen were clueless of what I was trying to do or what I needed .
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
Old 10-19-2015, 08:51 AM   #2
mcnabbwr's Avatar
Following too see how this works, and if there is a need for the Strongarms. My unit is pretty solid with the six jacks and X-chocks. Trying to figure out if there is a huge benefit or not. I have seen many post regarding the Strongarms but have never had them.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-19-2015, 09:05 AM   #3
TURBS's Avatar
I've got the fronts installed.
Still working out how to get them adjusted with the auto level.
Rears can't be installed until I get two more swivel clamps and bushings.
ID:	92096Click image for larger version
TURBS
2015 columbus 320RS
Old 10-19-2015, 09:10 AM   #4
Mod free 5er
Just make them. Bushings can be obtained at Lowes/HD/Northern Tool or use Heim joints which are better than bushings.
Old 10-19-2015, 09:36 AM   #5
Witch Doctor's Avatar
TURBS
2015 columbus 320RS
Get a hold of JT themselves or Lippert parts dept. and have the bushings and clamps sent to you. When I got mind I was missing one bushing they sent it to me, had the clamp. I'm sure you can get two more sets to do what you want. Remember you really have 4 front legs, which with there hard wear they only send 2 sets in the package for the front. When you put them on Stabilizers back you don't need them. The original reason for there design.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-19-2015, 09:38 AM   #6
TURBS's Avatar
Originally Posted by gljurczyk View Post
Get a hold of JT themselves or Lippert parts dept. and have the bushings sent to you. When I got mind I was missing one bushing they sent it to me, I'm sure you can get two more sets to do what you want. Remember you really have 4 front legs, which with there hard wear they only send 2 sets in the package for the front. When you put them on Stabilizers back you don't need them. The original reason for there design. I just drilled out the whole they were to go in until I got the other one still worked but wouldn't use it that way to long.
Lol did you miss the part about both guys being clueless at lippert?
Btw lippert owns jt strongarms.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-19-2015, 09:46 AM   #7
B and B's Avatar
Does OC need a road trip to the cold Midwest to help fab a bushing? Might be a nice thing to do..
B and B
Old 10-19-2015, 09:53 AM   #8
Mod free 5er
Would not use bushings, I would replace all bushings with Heim joints.
Old 10-19-2015, 09:56 AM   #9
TURBS's Avatar
Bushing cannot be replaced with a heim.
It's "not" that kind of bushing.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-19-2015, 10:11 AM   #10
Mod free 5er
Modify the ends.
Old 10-19-2015, 10:15 AM   #11
TURBS's Avatar
Modify the ends.
There is no reason to have a heim whatsoever.
The bushings go into the holes on your landing gear "one each side" then the swivel u bracket fits over leg and bushings then the pivot bolt goes through all pieces.
Don't see how a heim helps this situation?
TURBS
2008 duramax
2015 columbus 320RS
Old 10-19-2015, 10:17 AM   #12
TURBS's Avatar
TURBS
2008 duramax
2015 columbus 320RS
Old 10-19-2015, 10:24 AM   #13
Mod free 5er
Don't see how a heim helps this situation? TURBS
I just don't like bushings with bolts, too much slop in the fits. I connected mine to the pads themselves rather than to the leg posts. Heim joints have a much tighter tolerance and you can bolt them solid so the only movement is the clearance inside the spherical ball. Guess it's just a carry over from using nothing but Heims on race cars.
Old 10-19-2015, 10:26 AM   #14
TURBS
2008 duramax
2015 columbus 320RS
No I did not, just tell them you need two more sets, tell them you lost them. You don't have to explain why. That was your problem, you tried to explain something to lippert. I just said I had a bushing missing and they really sent 2. You might have to pay for them but they can still sell them to you.... Not many people put them on the level-up system. That is what is confusing them. They First told me I couldn't put them on a electric system, then they said yes you can when they talked to someone else at lippert. Then I went with hydraulic system so I no longer needed them and sold them to BombDoc. You can't use them on Hydraulics being the front legs are set at a 15 degree offset for stabilization.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-19-2015, 10:39 AM   #15
Mod free 5er
... You can't use them on Hydraulics being the front legs are set at a 15 degree offset for stabilization.
You might not need them, but you can still install a stabilizer from the frame to the pad.
Old 10-19-2015, 10:42 AM   #16
Only on the big foot pad. It would be sloppy on a 15 degree offset. Big foot makes a pad with a eye in it to connect, but I do not think they are offset. Maybe they are I really don't know, and my trailer is stable enough without hanging more stuff, they made a point of telling me NO, each system is different on what you can and can not do see attached
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-19-2015, 10:44 AM   #17
Mod free 5er
Ya need your glasses changed, I said from the frame to the pad.
Old 10-19-2015, 10:46 AM   #18
B and B's Avatar
The need is for a bushing, the Heim is not necessary or even required.
At the end of Round 1
Turbs 1 OC 0
B and B
Old 10-19-2015, 10:48 AM   #19
jtstromsburg's Avatar
For what it's worth(keep in mind this is on my lowly Sabre so maybe not comparable to your amazing Columbus) I only have jt's on my front legs with 4pt leveling and it seems more solid than when I had them front and rear with rear stabilizers. Fwiw
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-19-2015, 10:51 AM   #20
Left Coast
OC....when you flattened the ends of the black pipe, you heat 'em up? Black pipe being like the pipe sold in HD/Lowes used for natural gas?
