Old 03-31-2016, 06:06 PM   #41
Consider SteadyFast- less arms and the handle is easier on the hands. I've had a JT knockoff and the SteadyFast and the SteadyFast is a better product overall.
X2. Great product, easy install.
Sierra360PDEK is offline   Reply With Quote
Old 04-01-2016, 05:19 AM   #42
Michael4017's Avatar
Maybe I'm an exception but it took me about 5-6 hours to install the strong arms. I had to move the front jacks and don't have the impact guns/industrial tools that probably would've made the job quicker. I used my cordless drill and a ratchet set to get them installed plus with 2 kids and a wife thinking I'm just playing around I had to break it up over 3 days.
Wasn't the most fun install either....but they are on and seem to work pretty good.
'16 Cherokee 274DBH
'16 F150 XLT Crew 3.5eco
Mike
2016 Cherokee Limited 274DBH
2016 Ford F-150
Michael4017 is offline   Reply With Quote
Old 04-01-2016, 05:25 AM   #43
Justice12t's Avatar
Everyone has their own pace, there is really no prize for getting it done faster. I moved my unit onto the blacktop driveway which made it much better and used a corded drill and hand tools. I ended up having to move my propane line over a 1/2in so the JT bracket would fit. The real point is you did the work yourself and are/well hopefully enjoy the benefit either brand name provides.
2016 Prime Time Crusader 294RLT
2021 RAM 3500 Laramie Mega HO\CTD, CC, 4x4...ect
Days Camped in last 3 years - 79
Planned Days in 2021 - 50
Days Camped in 2021 - 0
Justice12t is offline   Reply With Quote
Old 04-04-2016, 09:39 AM   #44
i used used the Strong Arms for the first time this weekend.. We had 20 MPH winds and gusts up to 40mph. Typically this would rock the trailer. also, when ever anyone stepped up the stairs it would rock the trial. No rocking this time
We burned our "if the trailer is rocking, don't come a knockin" sign this weekend, cause we don't need it
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 04-04-2016, 09:42 AM   #45
TURBS's Avatar
[emoji106][emoji106][emoji106][emoji106][emoji106][emoji86]
Old 04-04-2016, 09:52 AM   #46
'16 Cherokee 274DBH
exactly what I thought.. but they seem to be worth it
Old 04-06-2016, 09:41 AM   #47
MacDR's Avatar
Hey Everyone remember to Bump your stabilizers up a bit after you tighten them up..
It really helps
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Month of July in the Egg Harbor Campground, Door County, WI
5 stars
MacDR is offline   Reply With Quote
Old 04-06-2016, 02:56 PM   #48
It really helps
I have to ask, what do they mean by bump the jack.....
'16 Cherokee 274DBH
Mike
2016 Ford F-150
Old 04-06-2016, 03:04 PM   #49
MacDR's Avatar
I always tighten my strong arms and then just raise my jacks about 1/2 inch to a inch to tighten them up a bit more.. It's actually in the JT StrongArm's Instructions..
2014 Columbus 340RK
Ready for Spring
2014 Columbus 340RK
5 stars
Old 04-06-2016, 03:09 PM   #50
Justice12t's Avatar
In my case I let the auto level run until complete. I tighten the JT's and then in manual mode I just "bump" the front jacks with a single quick press and release and do the same for the rear.
Old 04-06-2016, 03:11 PM   #51
MacDR's Avatar
Yes, That's perfect and it does help.
2014 Columbus 340RK
Ready for Spring
2014 Columbus 340RK
5 stars
Old 04-06-2016, 03:21 PM   #52
I thought that's what bump meant but wanted to make sure....
'16 Cherokee 274DBH
Mike
2016 Ford F-150
Old 04-06-2016, 03:36 PM   #53
I have found out that you can bump the jacks either up or down. All you are doing is taking the slack out of the mounting bolts. Either way will accomplish the same thing.
Old 04-06-2016, 03:49 PM   #54
TURBS's Avatar
2014 Columbus 340RK
Ready for Spring
Do you have the four point with the middle stabilizing jacks?
Old 04-06-2016, 04:00 PM   #55
MacDR's Avatar
I do, I added 2 BAL Scissor Jacks last year in front of my front wheels After I'm level and I bump the front and rear... I bring these down last onto a couple of 6x6 blocks just to snug up the center of the unit .
2014 Columbus 340RK
Ready for Spring
2014 Columbus 340RK
5 stars
Old 04-06-2016, 04:06 PM   #56
TURBS's Avatar
2014 Columbus 340RK
Ready for Spring
I have factory jacks in front of the axle and here's the problem.
After I auto level and tighten the jt's then manually bump up the front and rear to take up the slack it leaves my center jacks loose and no one has been able to tell me how to manually bump the middles up.
The center "stabilizing" jacks are only auto up or down. [emoji35]
Old 04-06-2016, 04:12 PM   #57
MacDR's Avatar
Arrggg.. Have you tried bumping down as OldCoot suggested.. Or can you add a bump switch to center jacks?
2014 Columbus 340RK
Ready for Spring
2014 Columbus 340RK
5 stars
Old 04-06-2016, 04:16 PM   #58
TURBS's Avatar
Hmmmm nope.
I'll try next time out.
Btw I'm sending you a pm shortly.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-06-2016, 06:56 PM   #59
What kind of auto level do you have?
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Dinostop is offline   Reply With Quote
Old 04-06-2016, 08:04 PM   #60
TURBS's Avatar
Lci 6 point fully automatic electric leveling jack system
2008 2500hd Duramax
2015 Columbus 320RS
