Old 03-29-2016, 06:34 PM   #1
JT's Strong Arm Jack Stabilizer system
Has anybody installed this system on a Travel Trailer ? If so did you put the 4 arms in the front by the hitch or in the back end of the trailer ? Looking to buy this system and wanted to know , I'm thinking of installing the 4 arms towards the back end of the TT..
dryhorn2 is offline   Reply With Quote
Old 03-29-2016, 06:39 PM   #2
Justice12t's Avatar
I just did this past weekend but on a 5er. The 4 are on the front in my case because that seems to be where the bulk of my weight is that needs stabilizing. I cannot say I have seen 4 in the back but if that's where it seems to make the most sense in your application then why not...good luck!
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 03-30-2016, 06:24 AM   #3
Canadian Member
itat's Avatar
I've looked at installing the JT Strongarms kit on my TT. It comes with 6 arms. I would probably put 4 on the front and 2 on the rear. Depending on your holding tank outlet you may not be able to install an arm in the front to back direction on that side.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 03-30-2016, 07:27 AM   #4
Mr. Dan's Avatar
I put 6 arms on my 5th wheel... "4 on the front and 2 on the rear."
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 03-30-2016, 09:02 AM   #5
4 on the front and 2 on the rear here too. Really helps!
Old 03-30-2016, 09:07 AM   #6
Left Coast
Have 'em on front, but added an elec. stabilizer in front of front axle
Old 03-30-2016, 09:19 AM   #7
Kaadk's Avatar
Mine has 4 on the front cause that's where Lippert put them. Also says to but them there in the install instructions...
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 03-30-2016, 09:22 AM   #8
Had to put them 4 in front and 2 in rear on my trailer. Otherwise i would have to remove the entry stairs.
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 03-30-2016, 11:52 AM   #9
Fulltime family RVer
Consider SteadyFast- less arms and the handle is easier on the hands. I've had a JT knockoff and the SteadyFast and the SteadyFast is a better product overall.
Old 03-30-2016, 12:19 PM   #10
Rock solid
I installed JT bars on my 2008 Cardinal TT. First I replaced the existing stabilizers with four 10.000 lb scissor jacks. Then I attached the JT bars to them. 4 in front, 2 in rear. I also had to bolt a 3/16" angle iron cross member at the rear to have a solid attachment for the rear JT bars. I will say my set up is rock solid.
rvfriendly is offline   Reply With Quote
