Old 08-28-2010, 12:56 PM   #1
RPAspey's Avatar
just tested this mod...
I got to thinking about a thread a few weeks ago about a bumper mount for a grill. Why not make one that folds away, easy to set up, and would be level with the camper. so here is what I came up with. the whole thing folds on itself, once i remove the grill and base. It stores on the hitch, but facing inwards. the grill and base, as well as the stem all stores in a plastic box inside a storage area. anyway, it only cost me about $10 excluding the hitch bumper adapter which I already had.
ID:	3259   Click image for larger version
ID:	3260   Click image for larger version
ID:	3261   Click image for larger version
RPAspey is offline   Reply With Quote
Old 08-28-2010, 01:08 PM   #2
Nice job. Which I had a friend that had a welder.
Old 08-28-2010, 04:53 PM   #3
Herk7769's Avatar
Now THAT is just plain cool! GRATZ
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-28-2010, 06:32 PM   #4
CLASS "A" Senior Member
cfsoistman's Avatar
Nice set up. Thanks for sharing the mod.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-28-2010, 06:37 PM   #5
Mr. Black's Avatar
I like it.
Now you can plumb into the trailers LP line with a quick disconnect and won't need the mini tank.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 08-28-2010, 10:11 PM   #6
That neat. If I'm not @ a racetrack, I could use the flagpole holder brkt on my TT in a similiar fashion. I may have to work on something like that for next year (chop saw is out on loan).
2017 Chevrolet K2500HD
2009 Rockwood 2106 Mini-Lite
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-28-2010, 10:20 PM   #7
Lightbulb
Originally Posted by Mr. Black View Post
I like it.
I couldn't find 1 listed on the 'net, but I found a 25' hose w/ male & female 1"-20 threaded connections. Allows me to move the portable BBQ I use, under the under awning if the weather isn't good.
Old 08-28-2010, 10:23 PM   #8
Mr. Black's Avatar
I am not sure who makes the hose but our Sierra came with a grill, rack, and quick disconnect hose assembly. It is mounted in an area under the awning. The propane fitting is behind the right rear wheel.
I like the OPs grill though. I would like to find that grill and make it work with our rack.
Steve
Old 08-28-2010, 10:41 PM   #9
Mr. Black, your's is probably a RVQ, that in doing some research is a low pressure grill. Low pressure in that it sources the propane after the regulator. I had 1 that came w/ my Jayco popup.
If the grill (BBQ in Canada) is teed off the tank (before the regulator) w/ a Stay-A-While or a separate bottle, it's a high pressure unit that has it's own regulator.
Old 08-28-2010, 10:46 PM   #10
Mr. Black's Avatar
Good call. Didn't think about that and I should have.
Steve
Old 08-28-2010, 11:00 PM   #11
No problem. Can still be hooked up to the trailer's propane, just a little differently.
Old 08-29-2010, 10:41 AM   #12
RPAspey's Avatar
lowes has these grills. works good
Local lowes has these. you can find similar on web for more $$
Old 08-29-2010, 10:46 AM   #13
Villa Estate 392FLFB
The_Stuff's Avatar
id love that mod but thats a long walk to the back of my unit lol
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 08-29-2010, 04:22 PM   #14
Talking
A 2 beer walk?
Old 08-29-2010, 04:30 PM   #15
Question
RP, it's kind of hard to tell from the pic, but does the upright piece of pipe rest on the ground or not?
Old 08-29-2010, 05:48 PM   #16
The_Stuff's Avatar
yes close to 2 beers. its 35ft from front door to rear bumper of trailer lol
Old 08-29-2010, 07:57 PM   #17
RPAspey's Avatar
no...
it doesn't touch the ground. It does adjust for different elevations. Also, the arm that pivots can be quickly placed below the "out rigger" arm and even flipped upside down to lower the grill even more. It proves to be handy as sometimes our choice of camp sites may be a field with a head up or head down orientation.
I used threaded pipe so I can swivel the grill ass needed then to stow away, I unscrew it from the base and place it into the storage bin.
Bob
Old 08-29-2010, 09:53 PM   #18
backin15's Avatar
Very cool! Thanks for sharing your mod!
backin15 is offline   Reply With Quote
Old 08-30-2010, 09:50 PM   #19
powerboatr's Avatar
great job
i have been looking for ideas to make mine a swing out and then hide in a compartment, your hinge there just solved my problem
great job
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 08-31-2010, 01:47 AM   #20
Very nicely done Looks great and sure it works great too
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
